Banging and no power - Defender Source
Old March 14th, 2012, 12:25 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
So I replaced the thermostat after thanksgiving due to it overheating on the drive back from my parents house in pa. I ended up taking two of the plug wires off the dizzy so I could get at the bottom bolt. Put it back together and now I get a banging that shakes the truck at idle. I'd swear the wires are on the right way. When I tried driving the truck last weekend. It's acting like the exhaust is clogged. Which wouldn't surprise me since the muffler is original. So my question is what's causing the banging?
Jimmy Buffett
Old March 14th, 2012, 12:35 PM
Is it the same as video in the Knocking Sound at Idle thread just a few down from this thread?
Old March 14th, 2012, 12:46 PM
flippedrover
Tyler
'94 D-90
Not sure I'll have to check when I get home the wifi I use at work sucks for downloading anything but text.
Jimmy Buffett
Old March 14th, 2012, 01:11 PM
if it's only 2 wires ... swap them and see if that fixes it ...
Old March 14th, 2012, 01:56 PM
Can you describe this banging better? This is not a good week for me, but maybe by the weekend I could make time to come over and take a look.
Originally Posted by pendy
I'm here for the D's
Old March 14th, 2012, 02:10 PM
Naplm00
Matthew
Ditto
trace them back and see if you put them in the wrong spot or that you pulledout the insulator when removing the boot from the plug.
IF they are all good you can stat the truck and remove the wires one by one slowly listening for the electricity arcing to the plug. If you notice that the truck running does not change ona partcular cyl, you have prpbably found the one that is misfiring. (as in when you remove it it does nto run even worse)
you can then swap the known bad plug wire for a known good and change out the plug, eliminating the issue from plug to wire. They you can check the dizzy cap or compression on that cyl for problems,
Old March 14th, 2012, 05:36 PM
flippedrover
Tyler
'94 D-90
Not like the one in the video. I'll play more with the wires this weekend. Charles if you can make it over that would be great. it shakes the truck and happens regularly when i idle it in the driveway.
Jimmy Buffett
Old March 14th, 2012, 05:38 PM
Tyler do you have a bananna in your tail pipe ?
Old March 14th, 2012, 05:50 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Take the banana out of the tailpipe and swap the wires. The banging shouldn't be too loud, but more of a hesitation sputter. Its just firing on the wrong cylinders at the wrong time.
http://i384.photobucket.com/albums/o...Wiring_opt.jpg
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 15th, 2012, 05:01 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Depending on which wires are crossed he could be hearing popping through the intake making the whole truck shake. A miss fire through the intake can sound pretty violent!
85 D110 3.5 3 DR
Old March 15th, 2012, 12:23 PM
flippedrover
Tyler
'94 D-90
The banana fell out a long time ago. Tailpipe is too rotten to shove anything in.
Jimmy Buffett
Old March 15th, 2012, 09:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I have heard that before....
Land Rover 110
Old March 17th, 2012, 06:33 PM
Bingo, just 2 crossed plug wires. Tyler needs to brush up on his reading of diagrams upside down.
But I think it was just his trucks way of letting him know it wants to get out more.
Old March 19th, 2012, 12:32 PM
flippedrover
Tyler
'94 D-90
Thanks again Charles.yeah I need to learn to read upside down.
Jimmy Buffett
