BANG! Power steering gone, coolant everywhere, truck dead. - Defender Source
Old July 15th, 2011, 08:28 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Unhappy BANG! Power steering gone, coolant everywhere, truck dead.
Uggh. After just telling someone I've only been stranded once due to a stupid relay my truck dies a block a way from my house. (convenient at least.)
I heard a pretty loud bang!! with a rattle and 15 seconds later the power steering went, then I smelled coolant and then the truck died.
I expected to see the fan jammed into the radiator but I didn't. There was coolant all over the upper bonnet and even out the front grille.
I took a photo - please tell me the pulley on the fan is supposed to be at that angle!
What happened? FYI - I recently had the alternator replaced.
Thoughts?
Old July 15th, 2011, 08:32 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Looks like your water pump just died.
- Charles Eames
Old July 15th, 2011, 08:44 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Water pump came apart. Not too uncommon after replacing the alternator as you re-tensioned the belt and pissed off the water pump bearing.
Old July 15th, 2011, 09:19 PM
and looks like the failure caused the belt to come apart, which knocked one of the radiator hoses off, which spraid coolant everywhere. the loss of the belt also explains why you lost power steering, as there was nothing turning the pump.
no worries. as long as the radiator isn't damaged, the water pump is pretty easy and cheap to replace.
Old July 15th, 2011, 09:25 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Thanks guys. Yeah the radiator looks fine. I don't remember there being that angle on the pulley though. I hope that's normal. Funny I've owned 2 D90s for the last 10 years and I can't recall that angle.
Alas - always an adventure...
Old July 15th, 2011, 09:56 PM
Just did the same with my disco 2 weeks ago on an interstate mountain grade. I cooked the 4.0 looks like you were more fortunate. Took the heads off the next day and dropped them to be shaved-got the call too warped to save.
Old July 15th, 2011, 09:58 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
If you're going to do the replacement yourself, I would humbly suggest also swapping in a new viscous clutch. And maybe the fan, too.
-Ren Ching
Old July 15th, 2011, 10:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
Same thing happened to mine. Looked the same. Sucks but easy to repair
Old July 15th, 2011, 10:57 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
The pulley is at an angle because your bearing failed...replace water pump, viscous clutch an fan while your there....
coolant
power steering pump mounting brackets punter Defender Technical Discussions 6 November 15th, 2010 07:31 PM
1984 Defender 110 power steering line washer/seal (low pressure side) cgalpin Defender Technical Discussions 3 February 23rd, 2009 12:52 PM
Leaky power steering box Lindy Defender Technical Discussions 15 January 26th, 2009 04:31 PM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
