Ball joint on top of rear axle - Defender Source
Old February 26th, 2011, 03:04 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Is there any way to get this off without removing the entire axle?? The nut on the bottom came off fine but can't get the ball joint to budge at all. Can't reach the bracket bolts or I would take those off. Any suggestions?
Thanks, Mike
Old February 26th, 2011, 03:09 PM
I haven't tried it but I'm told driving/braking a short distance with the bolts loose will do the trick
Old February 26th, 2011, 03:24 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks Doug, worth a try...
Old February 26th, 2011, 03:36 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Keep the nut on there if you try that. Hitting it with a BFH works too, better with a soaking of Kroil first.
axle
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
Soft Top Rear Tire Carrier dannr09 Wanted 1 August 3rd, 2005 08:21 AM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
