Badger top mounting rail info - Defender Source
Old July 21st, 2007, 02:38 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Im recieveing a Badger 2 soon and need to put the mounting rails on my '94. I need the side rails and back rails.. and.. thats it? I know I have to modify the windshield header a bit, any other mods necessarty for a 94 that has lived its whole life with the Tickford?
Are the side rails sold as one part # and the back kit sold as another part#? Can I nut/bolt or should I rivet, is there a factory part # or dimensional spec for the correct rivets??
Thanks alot, I've been getting rained on for too long, can't wait to have a bit of isolation from the elements... It's been a while since anyone's wanted to ride in the D!
~Steve
Old July 21st, 2007, 04:51 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Steve,
I recommend the belt rail kit from Rovers North ($47.25 and part #LRNA71707). It comes with the 2 side bars, and 2 back bars and instructions.
They also sell the aluminum rivets you need (#78248). Or you can use standard 3/16" aluminum rivets. I think that is the right size. If I remember correctly, I used the 3/16" diameter rivets that are 1/2" long.
You will only need to drill out a few of the back existing rivets and drill some new holes for the new rivets along the side. I held the bar in place with some clamps, marked the holes and drilled away. 5 minutes later it was ready to go. Probably the easiest thing I ever mounted to the Defender.
Also, the instructions will tell you to add some spacer washers to a few of the back rivets. You will see what I mean, but it is definitely a good idea.
Good luck!
Greg
Old July 21st, 2007, 07:25 PM
I'm in New Windsor NY right now if you need to look at my truck for placement or drilling reference.
Old July 22nd, 2007, 12:27 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Thanks for the info Greg, and thanks for the opportunity Jim. Ill be doing this in early august (on vacation now) so I cant really come up to NY to check a truck out. Maybe then!
~Steve
badger, mount
WTT/FS Badger II soft top silver grey efournier For Sale - Parts 8 June 26th, 2007 08:43 AM
1995 Bestop Soft Top (Belt rail) - FOR SALE jam90 For Sale - Parts 7 January 11th, 2006 10:50 AM
Soft top rentention rail Jase Wanted 3 June 30th, 2005 10:38 PM
Which Badger soft top?? CDN38 Defender Technical Discussions 16 February 21st, 2005 07:20 AM
Badger Top Colors for Alpine White D-90 ronward Defender Technical Discussions 12 January 12th, 2005 10:43 AM
