Badger II GK or FDS? - Defender Source
Old November 16th, 2015, 06:04 PM
TRS
Tyler
94 D90 ST #304
So I just had an hour conversation with Chris and I have to say you can tell he is a one man shop that is passionate about what he does. Chris didn't need to take the time to describe everything but he was more than happy to. Now here's the question, should I go with the FDS or GK version? Positives and negatives of both? Any chance there is somebody in the Denver area that has one I could check out?
Old November 16th, 2015, 06:29 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Will your truck be principally garaged or parked on the street?
Old November 16th, 2015, 06:30 PM
TRS
Tyler
94 D90 ST #304
Garaged
Old November 16th, 2015, 06:38 PM
down_shift's Avatar
down_shift
Russell
Then I would go with the FDS (but most here go with the GK).
Old November 16th, 2015, 06:50 PM
TRS
Tyler
94 D90 ST #304
So why do most go with the GK and why do you recommend the FDS?
Old November 16th, 2015, 07:24 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
I have had both. Go with the gutter kit. WAY better fit. I'm in Highlands Ranch/Lone Tree if you want to take a look.
Old November 16th, 2015, 08:21 PM
down_shift's Avatar
down_shift
Russell
Seen them both as most have here. If you have solid doors that close flush/square, window tops that are not wobbly, and take the time to correctly install the top, the FDS seals tight to the windows. Good as the GK with Puma doors? No, but what is the point having a ST at that point. Besides, the GK looks blotched on when going topless and ugly in general.
Old November 16th, 2015, 08:26 PM
Grover's Avatar
Grover
GK cost more but has a better seal around the door frame.
FS is less $$$
You would be happy with both...I went with GK B2 5 years ago and still seals tigh as a drum!
Old November 16th, 2015, 10:01 PM
TRS
Tyler
94 D90 ST #304
Chris I'll take you up on that if you don't mind. Thanks for info all
Old November 17th, 2015, 12:21 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I have the GK but I think I bought my top before he started making the FDS. Personally I like the look with the top off. That said if you want to run a surrey or bikini in the summer you will have to either remove the gutter kit of have the surrey or bikini modified to fit.
Jimmy Buffett
Old November 17th, 2015, 01:11 PM
I have the GK version and Brian has the FDS, both are really nice. I'm partial to running full door seals on the GK and have the roll up sides on the back making it a surrey. Brian's is a tighter fit but you have to remove the windows to use it as a surrey.
It's really personal preference but if you have or are considering roll up doors I would go with the GK.
95' D90 - daily driver..
Old November 17th, 2015, 01:23 PM
toona's Avatar
toona
Toona
1994 D90
I have the FDS and am very happy - though mine is garaged. I just wish I had gotten tan instead of black.
Old November 17th, 2015, 01:59 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
There are pluses and minuses with Both. I should note I am running a Badger I and Rob is running a Badger II. I've never had a problem with my FDSs. What would make it better would be full doors. The half door tops seem to pull away at speed.
The big reason I went with FDSs is I didnt want the GK. I take my top off for the summer and run just a surrey. I didnt think the extra cost was justified.
I think as long as you have a Badger you will be happy.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 17th, 2015, 03:01 PM
Grover's Avatar
Grover
I dig the galvy drain channels...
Old November 17th, 2015, 03:23 PM
TRS
Tyler
94 D90 ST #304
Definitely the input I wanted. Thanks everyone!
Old September 28th, 2016, 01:47 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
For any of you with either half cab do you get water pooling on the tonneau when it rains? If so what do you do to alleviate that?
Old September 28th, 2016, 02:43 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
over the years i have seen some homemade wooden bows that have been screwed into the capping rails to keep the water from collecting.
Old September 28th, 2016, 04:48 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Mine actually came with one from whoever I bought it from on the list (can't remember it has been so long). I didn't know if that was from Badger or just a PO rig. Unfortunately, it doesn't quite fit. I need to either shave it down an inch or wait for the top to stretch a bit more.
Old September 28th, 2016, 04:54 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Mine came with the wooden bow from Badger and nice metal retainers that screw to the cappings. The tub widths are not universally identical enough for the wood to be perfect and Chris mentioned that I might need to cut mine to fit.
Old September 28th, 2016, 06:11 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ok sounds like I got the same rig. Does it work keeping the water from pooling? Do you leave it there all the time or just put it up in times of potential rain?
badger
Badger 2 GK Top to TRADE for Badger FDS ssi19 For Sale - Parts 3 February 22nd, 2014 10:36 AM
Pictures of Badger Works Badger II FDS top MC36 Misc. Chit-Chat 3 June 20th, 2013 12:19 AM
Badger Half-Cab FDS Treuwer For Sale - Parts 36 August 6th, 2009 10:40 AM
Badger II FDS for sale CWF For Sale - Parts 19 February 3rd, 2009 01:21 PM
Badger I FDS Wolf Fabrication The Flea Market 2 March 25th, 2008 07:11 PM
