Badger II GK Leaks - Defender Source
Old July 9th, 2015, 09:54 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Badger II GK Leaks
I have a Badger II GK top on the 90 and when it rains water pours in the truck above the door top. It appears to be between the doors seals and the door tops. Any ideas on how to fit this better? I haven't replaced the door seals but I have taken them off and re-fit them. No change. The door top appears to be snug against the seal.
And I don't have a great seal between the sides and the door tops. Should I be tucking the top under the GK track there or is it supposed to sit over it?
Now that Boulder is turning into the Pacific NW I need to stop the water ingress.
Old July 9th, 2015, 10:06 AM
bjf's Avatar
bjf
barry f
94 ST #395
You need to post pics.
Old July 9th, 2015, 10:18 AM
Yeah post pics. You can also try angling your door tops in a bit more at the top(s).
Old July 9th, 2015, 10:34 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
mine does too but i have wagon doors on as well.
the drivers side gets soaked. the passenger side is dry as a bone.
i think i need to take the top off, cheat it towards the drivers side, then tighten it all back down and let the passenger side get soaked. =)
Old July 9th, 2015, 10:44 AM
Also make sure you have the top actually tucked into the top section of the "gutter" and then velcro'd securely through the gutter kit up through the footman arms...oh and even on both the driver and passenger sides.
Old July 9th, 2015, 10:46 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
My bet is top curve of the windshield under the header bar, pull the header bar and get a coil of dumb dumb. It is sold in a coiled rope, used to seal gaps I would put a bunch there and then reinstall the header bar. I do this on every Headerbar assembly, and really helps to seal the upper portion and keep you dry. Same thing with Wagons and the hardtop curve!!!
Old July 9th, 2015, 10:50 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
my water is coming in on the "inside" of the top of the door.
like the gutter kit is too far "in" towards the center of the truck. i have tried and tried to adjust it..... now i drive with a towel on my leg. =(
Old July 9th, 2015, 10:53 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by d90boy View Post
my water is coming in on the "inside" of the top of the door. like the gutter kit is too far "in" towards the center of the truck. i have tried and tried to adjust it..... now i drive with a towel on my leg. =(
try putting some dumb dumb in the top corner of the door seal, I have had to do that as well.
Old July 9th, 2015, 12:27 PM
RickM
Rick Mabus
95 D-90 ST
Ironic timing. I am currently having a gutter kit Badger II top repaired. The shop working on it asked about a bracket that holds the vertical side of the top up against the gutter kit in place. I reached out to Brewie212 about this seconds ago, as I purchased my GK from him. Anyway, for the life of me I cannot remember if the top had a part inside it that buts up against the gutter kit.
Disregard. Brewie212 just set me up.
RickM
Old July 10th, 2015, 09:33 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Right stuff also goes a long way to seal up the gutter kit between the header bar/windshield frame.
badger
Leaks - D90 Wagon Kimos Defender Technical Discussions 22 January 3rd, 2005 12:28 PM
When it leaks, it LEAKS Hans Misc. Chit-Chat 2 December 2nd, 2004 02:45 PM
windscreen frame leaks! Tawayama Defender Technical Discussions 0 October 30th, 2004 01:51 PM
Roof Leaks? Eric Siepmann Defender Technical Discussions 3 June 22nd, 2004 08:04 PM
window leaks artm Defender Technical Discussions 10 May 5th, 2004 11:34 PM
