Badger I with Gutter Kit Removal - Defender Source
Old April 22nd, 2010, 12:54 PM
Hey,
I tried using Badgercoachworks' website for the instructions, but it's either my browser is bad or his links are broken. Anyone have a PDF of instructions for the Badger I with gutter kit removal instructions? I'm not necessarily stuck, it's just that the PO had black silicone around the inside to seal it up a bit better, and I'm not sure if the top also came with some sealed spots between the GK and the top.
The PO said he included instructions, but I have been unable to locate. Searched badger's threads on here and he's never posted instructions as a new thread or anything. I search his posts now and see if I see anything, but if anyone has a PDF, shoot it to me please!
-Josh
Old April 22nd, 2010, 01:17 PM
specops1526's Avatar
specops1526
Beluga '97 90
You sure its not Rhinolined to the truck?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 22nd, 2010, 01:23 PM
Shut up and help!
Old April 22nd, 2010, 01:26 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
I have the same top and there is no adhesive holding it to the truck. Should just be held with the straps on the gutter system and the front rail from your pic.
Old April 22nd, 2010, 01:34 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Joshua,
The GK clicks in place on the roll cage/top of windshield then bolts to the tub next to the door. If need be call Chris I'm sure he will have no problem talking you through the process. If not I can take pic's for you? 'O' by the way - nice truck!
Weldon
Old April 22nd, 2010, 01:35 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
What he said. there's no sealant used on the Badger tops. Honestly to sure where one would use it. There should be three web straps that loop around a metal bar and Velcro back on them selves. And the front has a plastic strip that fits in the grove on the header bar on top of the windshield.
Jimmy Buffett
Old April 22nd, 2010, 01:41 PM
Thanks guys. Yeah, my confusion is mostly due to what the PO did then at the door horizontals (pics attached). Trying to remove the top, but it's attached to the GK horizontals.
ID:	26919   Click image for larger version
Old April 22nd, 2010, 01:45 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Hey Josh, X3 no goo or silcone...i just installed my gutter kit a few days ago. I phoned Chris and he was going to send me instructions. a bit late but if i get them i will PDF them for ya.
Also, can someone / anyone...take pics of what hardware the web straps loop around on the inside of the gutter kit? i just had 3 square holes. thanks...
Old April 22nd, 2010, 01:55 PM
Alright thanks! The black silicone sealed so well it felt as if the top's horizontal was bolted to the GK horizontal at the doors. Finally just cut a strip down the silicone and slid a screw driver in between to separate them. Pics attached. As you can see it didn't exactly come off without taking some of the paint or powdercoat with it though.
ID:	26922   Click image for larger version
Old April 22nd, 2010, 02:20 PM
specops1526
Beluga '97 90
Originally Posted by rijosho View Post
Shut up and help!
Haha, sorry, you know I couldn't resist!
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 22nd, 2010, 02:34 PM
She's officially topless! And yes that's an extension chord out of my apt to the computer so that I can be on D-90 while I'm doing this.
ID:	26924   Click image for larger version
Old April 22nd, 2010, 02:38 PM
I meant "Yeah, my confusion is mostly due to what the PO did then at the vertical part of the GK. Trying to remove the top, but it's attached to the GK vertical section."
Pretty much any time I said horizontal I really meant vertical. oops.
Old April 22nd, 2010, 02:42 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
Very Nice! love the NY backdrop!!!
Please, take a quick pic of the inside of your gutter kit where the velcro sraps loop around.
t.
Old April 22nd, 2010, 02:50 PM
specops1526
Beluga '97 90
What is that plate on the inside of your rear door?
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 22nd, 2010, 03:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
I am confused, did the previous owner feed the top into the gutter kit and then coat it with silicon to make it stay?
WTF then it started raining 10 minutes after I got the top off and went for a drive.
Old April 22nd, 2010, 03:27 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
looks like a mount for a sub? Glad to see you ended up with a nice truck josh. Even with the scandalous application of silicone on a perfectly good badger top
Old April 22nd, 2010, 03:28 PM
OK thank you now this is actually making sense. I was looking at how he had it set up and I was wondering how on earth people could be happy with the design, because it looked like the way he had it, when I cut the silicone, water and air would just enter the cabin.
What he actually did was run the badger's top along the outside of the Gk down the vertical part, and then sealed the two together with the silicon. What he should have actually done is run it through the inside of the GK down the side, and then seal up and leaking areas (if any).
This was why I was so confused guys!
------ Follow up post added April 22nd, 2010 03:30 PM ------
Yeah I talked to the PO today about some stuff and he said he usually just exacto-knifed the silicone when he took the top off during the summers and then re-applied for seal permanence in the winter.
Old April 22nd, 2010, 03:31 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
It looks like the PO glued the top to the outside of the vertical plate (the one the paint pealed off) of the GK. On mine, you slip the top behind this vertical plate so you can see the exposed plate from the outside of the truck and the top will not catch the wind when you are driving. Does that make sense?
Sorry, you beat me to the post.
Old April 22nd, 2010, 03:36 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
You will learn fast to always bring the top with you or bring a surrey top with you.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
badger, kit
Gutter Kit Pictures Grover Defender Technical Discussions 8 February 2nd, 2006 03:59 PM
Badger Soft Top with gutter kit Tom B For Sale - Parts 2 December 16th, 2005 05:35 PM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Badger Gutter Rail Kit TDI Guy Defender Technical Discussions 3 March 24th, 2004 09:55 PM
