Badger Gutter Kit Hardware? - Defender Source
Old October 31st, 2013, 09:07 PM
KKilo23's Avatar
KKilo23
Kenny
Just picked up a GK second hand... need hardware.
Does anyone know what comes from Badger... bolts nuts etc. Quantity and size?
Old November 4th, 2013, 11:26 AM
KKilo23's Avatar
KKilo23
Kenny
Here is what I have...
What am I missing to properly install Badger II GK top?
ID:	83460   Click image for larger version
ID:	83462   Click image for larger version
ID:	83464   Click image for larger version
Old November 4th, 2013, 12:14 PM
On your gutter fins you have 3 slots and 3 holes above them. You need 3 footman loops per side and will need to rivet those into place, otherwise the straps coming in above your driver and passenger doors have nothing to loop up through. Badger usually has them in stock, or you can just order some from elsewhere...they're pretty standard. Aside from those, I can't remember if the bolt that goes down into the tub behind the doors has a captive nut underneath...take a look. Otherwise, for the other hardware, just pick bolts and nuts that are long enough to get through the gutter kit, but short enough that they're not sticking way into the cabin, as you don't want your head hitting one while on the trail.
Here are some old pics of mine:
http://www.defendersource.com/forum/...1&postcount=26
Old November 4th, 2013, 12:20 PM
KKilo23's Avatar
KKilo23
Kenny
Awesome.. This is exactly what I needed. Thanks!
EDIT: Did you need to trim your header bar?
Old November 4th, 2013, 12:25 PM
Do not trim your header bar. He has it in some of his instructions, but there is absolutely no need. You can see that the snap is still on the header bar in the very bottom right of this photo. I'll be at Howard's this coming weekend; if you're still planning on attending, I can look at your set-up then.
http://www.defendersource.com/forum/...0&d=1271968754
Old November 4th, 2013, 12:29 PM
KKilo23's Avatar
KKilo23
Kenny
I will be there.. not with the defender... bringing the disco.
Old November 5th, 2013, 12:20 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Do not trim your header bar. He has it in some of his instructions, but there is absolutely no need. You can see that the snap is still on the header bar in the very bottom right of this photo. I'll be at Howard's this coming weekend; if you're still planning on attending, I can look at your set-up then. http://www.defendersource.com/forum/...0&d=1271968754
I had to trim my header when I installed my top so I'd say see if it fits with out great. But be prepared to trim.
Jimmy Buffett
Old November 5th, 2013, 07:45 PM
KKilo23's Avatar
KKilo23
Kenny
Anyone have the rough size of the opening on the footman loops?
Looking for measurements on "A" & "C"...
Name:	Footman Loop Spec.jpg
Old November 5th, 2013, 08:07 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Should just be able to buy them from a rover parts seller?
Old November 5th, 2013, 08:35 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I think rover farm has them.
What were the square holes originally for?
badger, kit
Gutter Kit Pictures Grover Defender Technical Discussions 8 February 2nd, 2006 03:59 PM
Badger Soft Top with gutter kit Tom B For Sale - Parts 2 December 16th, 2005 05:35 PM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Badger Gutter Rail Kit TDI Guy Defender Technical Discussions 3 March 24th, 2004 09:55 PM
