Bad Voltage Regulator? New alternator? - Defender Source
Old April 29th, 2013, 01:43 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Guys,
I have a rover V8 3.5L engine. Engine was stalling, so I changed fuel filter, cleaned out the carbs, put Sea Foam through the fuel tank. Stalling went away for about 90% of the time. Then, I started to notice that while running, my battery indicator slowly decreases, to the point of stalling out every once in a while.
I thought maybe a bad alternator or battery. All lights are normal intensity. Tested battery, battery read 12ish. So, that tested good. Then, after using AutoZone's Battery tester, I tested the alternator. Diodes read fine. Voltage Regulator failed 3 times.
So, as I gather, I think I need a new alternator; and might as well replace the belt.
Question:
Anybody have a source or part numbers for a rover V8 3.5L alternator and belt? (keep in mind the 3.5L V8 alternator is mounted on the passenger side.)
Thanks!
-Ryan
Old April 29th, 2013, 04:11 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Just replace the regulator--any decent alt shop could do this for you if you don't want to do it yourself. Just my advice on that--it will cost way more to buy a new one. Here is a Atlantic British link for the belt/alternator if it is the one you are after... http://www.roverparts.com/nxt/?page=...n=Defender+110
Old April 29th, 2013, 04:28 PM
Find the part number and search the internet....
Old April 29th, 2013, 05:13 PM
BEIS's Avatar
BEIS
RYAN BEIS
No part number is present. That's why I'm asking if anybody has one available....
-Ryan
Old April 29th, 2013, 05:35 PM
Look it up.... You can download a parts catalog here: http://www.landroverweb.com/landrove...-rover-manuals
Old April 29th, 2013, 05:54 PM
belt is ETC 7394
LHP26 isn't acting right on the alternator, pretty sure its a 55amp unit but that supercedes to the 65amp 200tdi part
Old May 3rd, 2013, 02:04 PM
BEIS's Avatar
BEIS
RYAN BEIS
Still going to attempt to get the alternator remanned, but managed to get in contact with George at Rovers Down South (RDS) in New Orleans, LA. He mentioned that the part number is RTC5683. It is a 45 amp alternator. Thanks to all who helped out, and especially George!
-Ryan
Old May 3rd, 2013, 02:14 PM
I would suggest, if you are buying an alternator to get one of the 65 Amp ones. They are a lot better. They are not expensive.
alternator
alternator circuit voltage drop and ripple voltage values JFD Defender Technical Discussions 2 November 29th, 2010 08:13 AM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Alternator and Regulator (Diodes) arbik Defender Technical Discussions 3 April 14th, 2005 05:20 PM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
» Defender Registry
Meh-Teh
thewap
Hunter
andy110
Add your Defender
