Bad vibrations - Defender Source
Old September 5th, 2015, 05:42 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Bad vibrations
A friend drives a DiscoI with 300tdi engine, R380 and about a 2" lift.
This was fine untill he swapped a ZF auto gearbox.
Since then he has bad vibrations when driving more than 90m/h.
Torque inventer and flex plate had been changed: same vibrations
He had changed several types of transmission boxes: same vibrations
Took the front shaft out while driving in diff-lock mode: a little bit smoother vibrations
He's thinking about the gap inside the main shaft inside the auto gearbox. It's about 0,8mm.
Expereances are needed.
Quickly if possible.
And a tipp about how to measure the gap the easy way!
Thanks.
Kurt
Old September 5th, 2015, 05:51 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
The problem is he switched from a manual to an automatic. Put the R380 back in and it will be fine.
Is he using the same drive shafts?
Black Rhino Lives Matter
Old September 5th, 2015, 06:22 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
He wanted an automatic like me.
Drive shafts: good question. I guess he replaced them by wide angle or double joint types.
But it doesn't matter, both sytems failed: because bad vibrations
Old September 5th, 2015, 06:41 PM
We had a similar question a few days ago.
1: check UJ for play and regrease
2: check props hafts at both ends to make sure the nuts securing then are tight
3: one extra one: ditch the guibo/rubber donut for real props haft
Old September 5th, 2015, 06:55 PM
People can actually do 90 miles per hour in a Rover? Seriously?
Old September 5th, 2015, 07:01 PM
I did driving across the country.
Old September 5th, 2015, 07:10 PM
This is flabbergasting. Who knew.
Old September 5th, 2015, 07:14 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I'm sure he checked it all over the place several times!
No ideas about vibrations inside the automatic transmission?
Old September 5th, 2015, 10:08 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
A binding u-joint will cause a vibration before there's any play in it. And it can only be checked by removing the propshaft.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 5th, 2015, 11:08 PM
Thanks Tom and others for adding good stuff to my comment. Thumbs up!
Old September 6th, 2015, 08:17 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I'm sorry for this mistake. A small "k" is missing.
The vibrations start at 55 m/h.
Old September 6th, 2015, 03:56 PM
Etienne's Avatar
Etienne
Etienne
Tdi 2500 diesel Defender 1985
Had a problem with vibration. Checked many many things. eventually found the big nut on the pinion gear on the front of the rear diff was 'loose'. the shaft could be pushed and play felt. tightened the nut to 90nm and vibration was gone,
Old September 6th, 2015, 05:20 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Had a similar issue and it turned out the bolts securing the driveshaft to the back of the transmission were slightly loose causing the break drum set screws to work loose and then the parking brake drum to rotate and wear the holes oval where it fits onto the rear flange.
It was pretty ease to diagnose.
RDavisinVA
Front Diff Vibrations 1of40 Defender Technical Discussions 3 February 6th, 2008 10:41 PM
vibrations and noise Big D Defender Technical Discussions 4 September 5th, 2007 10:13 AM
Vibrations again.. sflash868 Defender Technical Discussions 3 April 22nd, 2006 11:24 AM
Good Vibrations Doug_Paoletti Defender Technical Discussions 6 May 24th, 2004 09:12 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
