Bad Throwout Bearing - Defender Source
Old September 13th, 2010, 11:32 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I have this awful "bearing" noise coming from the rear engine/tranny/tcase area and am thinking it might be the throwout bearing. When it goes bad, would it potentially make a lot noise. Anyone experience this?
Semper Fi!
Old September 15th, 2010, 05:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
This noise ended up being the t-case front output metal dust cup working loose and rattling around. Whew!
Semper Fi!
Old September 15th, 2010, 05:29 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah. A release bearing usually doesn't make noise unless you're using the clutch.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
