BAD squeeking from below - Defender Source
Old February 12th, 2007, 06:29 PM
I have a noise that makes a consistant sqeeking at low speeds. My gf noticed it this weekend. I noticed it yesterday afternoon after driving down from western NC to Greenville sc. Started as a barely noticable sqeek i could hear slowing down to stop maybe arond 0-10 mph. now its gotten a lot more noticeable and I can hear it moving a long upwards to 30 then i think all the other noises kinda drown it out. it does it when i mash the brakes it does it in reverse and when its not in gear. All my fluids are fulll as of last weekend. seems like it is coming from the rear of the vehicle. thanks for any help folks. O yeah I took the truck by my trusty always reliable independent shop and they gave it a clean bill of health go figure.
Old February 12th, 2007, 06:45 PM
huck1974's Avatar
huck1974
shane cates
94 d90
trying to brainstorm..
what about the drum trans brake?
can you hear it at really low speeds?
can you hear it coasting while the motor is off?
can you get under the truck and have someone push it back and forth to locate the issue?
Old February 12th, 2007, 07:01 PM
i can hear it coasting while the motor is idle. i really dont think it could be the drum brake thats a good idea though. I know my transfer case leaks and i wouldnt be suprised if the shoes could be contaminated. ive rocked it back and forth and havent heard it.
Old February 12th, 2007, 07:07 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
u joint?
Old February 12th, 2007, 07:25 PM
Cirbo's Avatar
Cirbo
Jim C.
Jack it up and spin some wheels... shake them checking for side to side play.... maybe bearings?
Old February 12th, 2007, 08:44 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I want to help. wish you were near my shop. we would throw it on the lift and fix it and then I would buy you a beer to have a fellow rover enthusiast in presence. anyways, if you could give us some more info, maybe we can help more. good luck. dealership=bad karma
Old February 12th, 2007, 08:57 PM
I had that happen to me with my disco. It was loose bolts on the exhaust, I think at the collector, which would also explain why in a shop with the engine off, nothing would be noticed.
Old February 12th, 2007, 09:48 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
How in the sam hell did you figure that one out?
"It's not a Jeep"
Old February 13th, 2007, 02:50 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I second the U-Joint. Hang your head out the back while someone else is driving (slow obviously). This way you can at least narrow it down to centerline or off to one side (i.e. driveline vs. brakes)
You could also stap a creeper to the frame and have someone take off. This way you could hear the noise better. Bring a can of WD-40 and you may be able to fix it on the go.
(last part was a joke)
Old February 13th, 2007, 03:38 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Could be the muffler bearings as well. Better check those.
Old February 13th, 2007, 03:47 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Sounds like something Keanu did in the movie Speed.
Neil
Old February 13th, 2007, 04:04 PM
no muffler bearings. u joints....
Old February 13th, 2007, 10:08 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I believe it is the hubcap bushings.
Old February 14th, 2007, 11:33 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
It could be the axel bearings as well.
Old February 14th, 2007, 01:39 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Yeah, mine went out last week.
Exspensive little things too.
Old February 14th, 2007, 02:31 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
It's tough to get Phil worked up. He's a laid back kind of guy.
Old February 15th, 2007, 07:04 PM
yeah man....
more diagnoising. squeek is coming from the right wheel zone. When I had it in low you could hear it squeak about every half revolution of the tire. only seems to get noticable once the truck is warmed up. maybe its a bearing but at 60k miles.. wheel bearings are tight and have been repacked. I dont think it a pinion bearing since its spining to fast to be the squeek I have.
Old February 15th, 2007, 07:49 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I had what sounds like the same issue. I couldn`t figure it out, so I just kept driving on it because everything was still functioning perfectly fine, and then one day it just went away.
Old February 15th, 2007, 09:23 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
The only squeak I've had so far is when my E brake wasn't disengaging from the drive shaft all the way. Part my fault..part adjustment on the brake cable needed. Squeaked when moving (engine off and on) up to about 15 MPH. Just a guess though.
Everybody else's advice is beyond my experience.
I'm happy you clarified that. Read a post here where some nut put his D on axle stands and ran the friggin thing up to 60 MPH in his garage. Nothing here surprsies me anymore.
Hey, Phil...I know you have a D but what the hell is that in your avitar? Looks like a surplus Iraqi SCUD launcher with rocket fuel squirting out of the bottom. Been curious for months.
"I ain't lost!!, ain't NEVER been lost...<Scratching head>Been a might confused fur a few hours...but I ain't never been lost."
Old February 16th, 2007, 12:35 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Looks like a well drilling rig to me.
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
