Bad Servo? - Defender Source
Old March 25th, 2006, 02:09 PM
dfscott
Daryl Scott
1994 Defender
Bad Servo?
I have a 1994 D90. I recently replace my brake light swith located on the way back of my pedal box. To replace the switch, I moved the pedal box, servo and master cylinder out of the way to get at the back of the pedal box. I did this by removing the 6 bolts securing the pedal box to the floor and pushing the pedal box up and out to get at the brake light switch. This moved the servo and master cylinder out of the way also because they are all hooked together. The brake switch worked fine.
However, the brakes did not fully disengage and the car ran with the brakes partially engaged grabbing and holding the vehicle back.
I tried adjusting the brake light switch. Brakes continued to grab.
I removed the brake light swith. Brakes continued to grab.
I withdrew the servo from the brake pedal box by removing the clevis pin from the brake pedal and withdrawing the servo from the pedal box. Brakes still grabbed.
I then removed the master cylinder from the servo and withdrew the servo from the vehicle. Brakes stopped grabbing.
Do I have a faulty servo or master cylinder?
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Brake Servo dimcon Defender Technical Discussions 0 May 26th, 2005 09:20 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
