bad radio reception / antenna question - Defender Source
Old May 3rd, 2012, 04:03 PM
davidr
David R
1997 D90 (Sold July 2014)
I have a 1997 D-90 and get crappy reception with the stock antenna (completely pulled up) in forest areas. I was wondering about power antenna's. I saw them referenced in a few posts but only vague comments or jokes about them. Anyone think it is a good solution and if yes, is there a brand one suggests?
David
Old May 3rd, 2012, 04:11 PM
do you mean an antenna amplifier?
Old May 3rd, 2012, 04:12 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Have you ensured yours has a good clean connection?
Old May 3rd, 2012, 06:36 PM
That's the last thing you want .... If you have crappy reception that will just make it worse ... As Tom says ... Make sure it's all clean and well connected. If you have to buy a replacement try hirschmann ... As fitted to German cars ..
Old May 4th, 2012, 10:07 AM
davidr
David R
Hi, thanks for all the replies. I think I meant an antenna amplifier, but, thanks for the replies. I'll check the connections first. The reception is great in urban areas and highways but bad on highways which run through woods, that's why I was thinking it's less of a bad contact issue and more of an amplification issue.
If it's not a contact issue, maybe I'll try that Hirschmann replacement.
Thanks!
Old May 4th, 2012, 12:27 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
SiriusXM :-)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Shark fin radio antenna paulb Defender Technical Discussions 10 February 21st, 2005 11:24 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
