Bad noise, suggestions needed... - Defender Source
Old September 12th, 2010, 03:15 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Question Bad noise, suggestions needed...
Last year I heard this noise coming from my side (driver's side) when turning left and with center difflock engaged.
It's a clear "clok crick crack clack".
Only when turning left, and with center difflock engaged.
Time went by and I finally stripped the whole hub in pieces at the beginning of August,
thinking of a worn out CV.
Pulled the Longfield out, CV was fine (after 5 years of 285/75 SSRs and random 36" 13 TSLs), the splined of the axles (CV side) were worn out instead , but still straight, not twisted.
It looked weird to me but I thought fair enough after 5 years of use and random abuse, and replaced the axle and the CV just in case...
Yesterday the noise came back.
Again, only when turning left and with center difflock engaged.
I haven't stripped the hub again (yet), but I'm scratching my head as I can't understand what the CV got to do with center difflock and why on earth only when turning left (if worn, shouldn't it "click" all time??).
If I engage the difflock and turn left on gravel or when in woods (soft/hard ground, sometimes slippery, sometimes not), I hear the noise.
If I engage the difflock and turn on grass, not a whisper.
Let's supposed the new CV and axle are fine...and not causing the noise...what else could it be?
I thought of...worn U-joint at the driveshaft?
I have zero ideas and I'm
Hints???
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old September 16th, 2010, 02:17 PM
ed110
Ed Downey
110 300Tdi SW
Have a look at the drive shaft. I had the same thing and the U joint was worn out on the front prop.
ed
Old September 16th, 2010, 02:26 PM
dchapman
Daniel Chapman
1999 D1
They'll do this when they're dry.
Old September 16th, 2010, 06:47 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Cause was much more simpler and stupid (and partly my fault), but I will check the U-joints anyway,
thanks!
Cube will be back rolling soon...
Michele
D90 VNTdi
[O]===[O]
Old September 16th, 2010, 06:57 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
thanks!
What was the issue?
Old September 16th, 2010, 07:10 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Bronze bushing popped out of place...
But it's 50% my fault
new CV, old bushing needed to be bored out like 0.0000000000000000000000000000001mm,
I didn't and nor did the machinist, so it got stuck to the stub axle and popped out...
All fine, no damage, just a waste of time and a parked D90...
Michele
D90 VNTdi
[O]===[O]
Bad noise Jpayne Defender Technical Discussions 5 March 9th, 2010 07:27 AM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
