Bad noise - Defender Source
Old March 7th, 2010, 02:19 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Bad noise
So lately when I come to a stop I hear a grinding noise in the front of the truck. It happens when I have the clutch in, and doesn't matter if I have the brakes on or not, but only occurs at a few MPH and only after the truck warms up a bit. It happens with a pretty rapid frequency, like it has something to do with the speed of the driveshaft or differential rather than the wheels. Any one else have this problem at some point in time? I might park it till I figure this out.
Thanks!
Old March 7th, 2010, 03:44 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
My parking brake drum has been doing that on and off for years. Took me a LONG time to find it, I initially started with pulling CV joints and all the front end stuff.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 7th, 2010, 08:41 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I was ready to jack up the front end and start turning the wheels to see what was going on.
So what do you do about that, just change the brake pads on that drum?
Old March 7th, 2010, 10:33 PM
Hans's Avatar
Hans
Hans Haase
Took it off, cleaned it up with a scotch bright pad, adjusted it, and put it back together.
-Hans
My oil line fix
Old March 8th, 2010, 11:57 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok thanks. It is getting worse and I'm pretty sure that drum is the culprit. When I was on my way home the truck was starting to shudder a bit at even higher speeds and felt really odd. I parked it and looked underneath and the drum was very hot and smoking. Bummer. I hope I didn't completely toast it.
Old March 9th, 2010, 07:27 AM
Hans's Avatar
Hans
Hans Haase
there isn't much too the whole assembly at all, not much to ruin other than the shoes.
-Hans
My oil line fix
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
» Defender Registry
Toby
Willh
Camel
Camel 422
Add your Defender
