Bad CV...Possibilty of further damage? - Defender Source
Join the Defender Source Community Today
Old September 7th, 2016, 01:42 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Ok, so I've got a 97 NAS with about 80k miles. I'm getting a grinding feeling/noise from drivers side front upon deceleration once I'm over 50-60 mph. The wheel bearings were replaced recently so I'm assuming it's the CV shaft. (Also ball/knuckle on that side is corroded so I'm assuming at some point the area had excess moisture which probably did not help the life of the CV)
I've got a big trip planned to the Silver Lake Sand Dunes in Michigan...leaving tomorrow. I'm trailering her to the dunes.
My question-what is the worst that can happen if the CV completely blows when romping in the Dunes. Considering I just put 35's on stock axles I understand this is almost inevitable to blow this weekend.
Old September 7th, 2016, 01:49 PM
Naplm00
Matthew
if it blows in the front you can lock the diff and disconnect front front Driveshaft and have emergency rwd.
Old September 7th, 2016, 01:53 PM
Bring an extra CV and axle shaft....it's ~2-hours to change one out after breakage (less if you do it beforehand since you don't have to pull everything apart to clean out the bits from the swivel ball). BUT expect that if it goes it tends to grenade inside of the swivel ball housing....so you need to take everything apart and clean it thoroughly. We were blowing stock CVs all the time, so just got "used to it" that changing one out sitting on the ground back at camp was inevitable. However, a few of us - myself included - recently changed over the HD CVs and axles....contact Erik or Justin @ Lucky8 and they can set you up - definitely a worthwhile upgrade.
That said, in order to "limp" back to camp you can sometimes pull the front flange cap while in the field...and depending on how bad the carnage is this should allow you to drive back to camp. Alternatively, pull the entire CV/axle where it sits (which entails pulling at least the outer inspection cover from the stub axle & sliding out the CV/axle and cleaning out the bits so it doesn't toast your lower swivel ball bearing). Just remember, that when it does pop on you it does like to send shards everywhere inside of the swivel ball....that stuff NEEDS to be cleaned out to avoid any further damage or stuff floating around. *If* the damage is not too bad, you can also pull the front driveshaft as Matthew mentioned...however, the couple of times it happened to me blowing a CV things got pretty "bound up" inside of there so in one instance I had to pull the flange cap and the other I had to pull the entire CV. You just want to avoid the wheel motion grinding anything else up in there that shouldn't be....
If it was me, get on the phone and track down someone locally that's got a spare CV/axle for the appropriate side. Then change it out either beforehand or when you get to camp before you go wheeling. Would save you a lot of agony if it blows in the wrong spot. Or, alternatively you can wing it and if it gets you through the weekend just tackle it when you get back...but at a minimum be prepared to go into limp-home mode....
Old September 7th, 2016, 02:12 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I like the idea of just changing it before if it's not that bad. I'm having a hard time finding one at any local auto parts stores. And these things loom expensive! At least on AB they are over $200. Seems like I should be able to grab a cheapo from Autozone or O'Reillys?
I'm going to upgrade my CV's this winter and also, this same side needs a new knuckle which I planned on tackling this winter. She gets stored when the snow starts flying so I'll have plenty of time to learn/endure the process
Old September 7th, 2016, 02:41 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Good advice from Jason. I've had a blown CV tear some stuff up.
Old September 7th, 2016, 03:01 PM
Not sure if the standard box-stores will stock the CV or not (I'm guessing probably not).
If you swap it beforehand, you can probably get away with just the CV knuckle (RTC6862) and change over the existing axle shaft to the other/new(er) CV. Keep in mind, this is the same as the Disco 1's as well so you can use one of those. Honestly, I would just put the word out to anyone you know that's going (or is local to you) and has a Defender/Disco1 and see if they have any in their box of spares....literally in my trailer I have probably 4-CVs that I keep in my "spares" box...you must know someone locally that is at least 1/4 as insane as I am .
How far are you from IamKraig? He's in Northwest Ohio, and is one of those folks probably even more insane than I am! He's probably got enough spares to build several trucks...
But for $200, I'd put that money towards an HD set from Lucky8....
Old September 7th, 2016, 03:51 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
You won't find anything for your 90 at O'reillys except spark plugs and oil filters.
What vehicle did you own before this?
Probably the worst thing that can happen, safety wise, from driving on a blown CV is that the pieces will jam up in the swivel housing and lock up the steering.
Old September 7th, 2016, 04:41 PM
Description does not sound like a CV to me.
Old September 7th, 2016, 04:51 PM
seaswood
Diesel
Gbr.
Great Basin rovers can rebuild it or answer your questions
Old September 7th, 2016, 07:44 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Sorry for the delayed reply. I'm just over the Michigan border in toledo. Piles of spares and happy to help. Just shoot me a pm and I will get you my cell.
Hope you have fun and finish without incident.
Kraig
Old September 8th, 2016, 02:51 PM
Heard Kraig hooked a brother up....that's why we keep him around !
Old September 8th, 2016, 02:53 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Pretty sure he supplied 2 or 3 shafts in a single section of VOT a couple years ago. He's a good dude for sure!
Old September 13th, 2016, 10:53 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Yes, he did. Thanks Kraig! Our trip went great with no issues! Thanks again!
ID:	157567   Click image for larger version
Further Pricing Advice Please - Side Seats Cuthbert110 Defender Technical Discussions 0 September 25th, 2015 04:34 PM
Blasphemy! Read no further! Jeep content! o2batsea Misc. Chit-Chat 31 July 29th, 2012 09:24 AM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
