Bad Cats and O2's - Defender Source
Old February 19th, 2010, 10:19 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Bad Cats and O2's
My cats and 02's are bad. Other than going full stock what other smart choices should I conisder? From the Cats back I'm good to go.
Old February 19th, 2010, 10:36 AM
Don't bother with NRP from RN. All things considered, stainless up forward is gilding the lilly. Mild steel holds up just fine. Cats back, stainless is a good option. Stock is OK.
Old February 19th, 2010, 10:39 AM
Freebie y pipe in NY if you want it. Its got miles, but the price is right.
Old February 19th, 2010, 10:56 AM
Jim I really need that if 1 of 40 doesn't!!
If it fits a 95 ...
Old February 19th, 2010, 01:14 PM
JimC's y-pipe is welded to the center section so you would have to redo the flange.
If it were me, I would just take off the y-pipe, hit it with a hammer to get the loose chunks out of the cats, and call it a day. My LWB has like no cats left (nothing I did, they just puked themselves out the back of the exhaust) and it runs great.
Old February 19th, 2010, 01:28 PM
I think I have a crack on the flange to the header on the good cat side ...
'redo the flange' is that something meinke could do?
Old February 19th, 2010, 02:01 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
If you want one of the weirdest experiences in your life you can bring it out to the boys by Citi field. They welded new cats into my y-pipe. They only take cash and they beg to work on your truck so you can get a good price.
But I am warning you it is the most bizarre place I have ever been. Its like a 3rd world nation, Mad Max & Labyrinth all mixed into one.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 19th, 2010, 02:08 PM
you make it sound so appealing ...
Old February 19th, 2010, 03:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used magnaflow "universal" cats on my D90. Paid about 75bucks each and welded them in.
Old February 19th, 2010, 04:22 PM
1of40's Avatar
1of40
1of40
Good advice guys! Thanks for the offer JimC. I'm going to puss out and go with a stock set-up from AB. New Y and O2's shipped is just under $1K. I've got to get through emmissions next month so I'm going to bite the bullet.
Old February 22nd, 2010, 12:29 AM
CDeWan
Clay DeWan
5.3L beastie
You could also go with headman headers from summit for $150 and and have the flanges and new cats welded in. I think I got out the door with headers, new cats and o2 sensors for around $800.
Old February 22nd, 2010, 10:57 AM
1of40's Avatar
1of40
1of40
Wow, under $800? What was labor?
Old February 22nd, 2010, 11:59 AM
I would have yours repaired or get an NRP one... I have the NRP on both trucks and it has been great.
Old February 22nd, 2010, 04:13 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Will the Headman Headers fit? I was under the impression that something had to be modified in order to fit these in the D90's...
Old February 22nd, 2010, 04:47 PM
CDeWan
Clay DeWan
5.3L beastie
Let's see -
Headers $150
O2s $100
Cats $250
Labor $300
I think that is how it worked out. Just make sure that try to tuck the cats up on the passenger's side so it doesn't hand below the crossmember leaving it exposed to a potential hit from the underside. I might be a bit off on the O2s, labor and cats price but I know overall it came out to around $800.
Hope that helps.
Clay
Old February 23rd, 2010, 09:52 AM
1of40's Avatar
1of40
1of40
Hey Thanks Clay!
Scott, what's sort of difference are you experiencing with the NRP cat/y-pipe? Performance?
catalytic converter 97 d90 boisdarc Defender Technical Discussions 2 February 20th, 2007 05:14 PM
Need help with check engine light Hammertime Defender Technical Discussions 3 September 14th, 2006 12:47 PM
removed my cats today(running rich?) mattdh Defender Technical Discussions 4 April 11th, 2006 05:22 PM
