bad bad BAD noise - Defender Source
Old December 11th, 2003, 05:48 PM
Unhappy bad bad BAD noise
Was trying to climb a hill today had the truck in low lock and 2nd gear got about 3/4 of way wheels started spinning so i let off gas, when the tires started spinning it sounded like the front diff had some transfer of power between both wheels sounded ugly on the way home about 5 miles or so i get this shitty sound. maybe a noise like a bearing is going bad or something but i think its a result of that power transfer between the front tires. I does it when i slow down but i didnt notice it when i was on teh gas. I am not sure what is wrong just thought Iwould try to get some input. It's definatly drivetrain related I recently replaced both diffs and the t-case with the mobil 1 gear oil however that isnt culprit. I am not sure if it is the diff or t-case or what. tomorrow i might take off front drive shaft and put the front on jackstand to see if i can notice anything. any input is welcome. o yeah its got 45k miles on it.
Old December 11th, 2003, 05:53 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Hmm.. sounds totaled. Better donate the truck to the site quickly.
Seriously though, Describe the sound... like is it grinding sound, steady? changes with the speed? Were you really spinning the tires then suddenly grabbed traction?
Chris von C
[/size]
Old December 11th, 2003, 06:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
How loud are we talking here??
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 11th, 2003, 06:25 PM
nah i dont spin fast that how shit breaks... the hill was muddy kinda, well wet but wasnt spining more than 5 mph if that wasnt like a grab of traction or something just power alternating between tires. as for the noise.. well came home drank a beer got my head back to earth since i was worried something was fucked up $$$$$$$$$ went back gotinfront ofthe truck and pushed and pulled it around the yard sounded like something dragging so i pulled on the dust shield for the brake and it stopped. right now I am having a really hard time figuring out how that was rubbing the rotor. maybe something is loose i doubt it though. right now no noise I am cooking so cant take the truck out. however the noise fron the drivetrain on the hill was a little un nerving but it happens sometimes and I dont worry about it. i have heard other defenders do it. I will take it for a spin shortly. the noise wasnt terribly loud maybe about well alot like if you were scratching your fingernailsacross a black board HARD and trying to make people cringe. I thought for sure it was the diff but on second thought if the diff was shithoused i think i would have problems going forward with the center unlocked as well as open diffs. we will see I will post later this PM if there continues to be a problem after i drive it. thanks.
Old December 11th, 2003, 06:26 PM
o yeah so far i have decided its in the front right of the truck, i grabbed the d-shaft and tiwsted, there is no more play than usual.
okay. so went and grabbed the front right tire and shook, something feels lose and when i shake it back and forth i get a kinda clunking metallic noise more of a thunka thunka than clink clink.
Old December 11th, 2003, 06:45 PM
exmodlad
Guest
Posts: n/a
sounds like a bearing or CV joint?????
Old December 11th, 2003, 07:02 PM
those are my thoughts..
Old December 11th, 2003, 09:32 PM
pcarey's Avatar
pcarey
Peter Carey
'93 NAS Defender 110 #322
yeah, it shouldn't make those noises. :-) I've had bearings go out on the rear hub which also caused problems with the differential (Detroit) and it wasn't until I heard the Detroit locking when it shouldn't that the problem became evident. Kinda made noises like you describe.
pwc
pwc
Old December 11th, 2003, 09:56 PM
hmm. what happened to your diff. i can handle having the bearings replace bu a new diff. well. i am not so sure
Old December 11th, 2003, 10:02 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I just had the U joints replaced on my front drive shaft.As I was driving I heard a loud noise like you described,the U/J had some metal missing and was not moving freely. Hope it's something as simple as my problem.
Old December 11th, 2003, 10:03 PM
me too
Old December 12th, 2003, 12:44 AM
pcarey's Avatar
pcarey
Peter Carey
The Detroit began making some horrid racket after little hints of noise on and off. It came to a point where it no long could disengage (forgive me for not having complete knowledge of the inner workings of a Detroit).
Sold it to a friend of mine for cheap who likes to work on things like that and he got it back together with a minimal amount of work in the end. It did take him some effort to get a full tech spec on the unit though.
I just wanted to point out that if you can move the tire in and out and there is noice, then the bearings could be shot on that side. When was the last time they were greased? And have you run them through much water? If the bearings go then there isn't much holding the shaft in place and it will transfer the wobble and force one way or the other.
pwc
pwc
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
