backspacing - Defender Source
Old November 22nd, 2003, 10:37 AM
Rick Carlisle's Avatar
Rick Carlisle
Rick Carlisle
1997 Alpine White D-90 SW
backspacing
I realize there have been tons of posts regarding tires and wheels, so please humor me here.
If I install 285/76/16 tires with 16x8 rims w/4 1/2" backspacing, will the tires stick out past the vehicle? Can I do this without trimming/cutting?
I have read what is said about the 285/75/16's but the backspacing of 4 1/2" vs. stock is what concerns me.
I have recently installed LR heavy duty springs on the front, medium duty springs on the rear, and bilsteins shocks.
Thanks for the help.
Old November 22nd, 2003, 11:05 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Rick, you can run those tires on even the stock rims with no problem.. Correct me if I'm wrong guys. Or run them on the 6.5"wide wolf rims with no prob.
Legend in My Own Mind.
Old November 22nd, 2003, 12:09 PM
Rick Carlisle
Rick Carlisle
Thanks Randy. Am I wrong in saying the 4 1/2" backspacing will stick the tire out more? or am I confused on this. I also have the option of going 4" backspacing but thought I would do 4 1/2" to lessen the chance of the tire sticking out.
Old November 22nd, 2003, 01:32 PM
tbmcneill
Guest
Posts: n/a
you're only talking ~3/4" difference .... stock is 5 & change. the tires will stick out more than stock. you MAY get mild rubbing depending on how much lift your setup gives you. you're certainly not going to have to start chopping flares, though. for comparison, i used to run 35x12.5R15s on 4" backspaced rims with 2" lift and only rubbed at >90% compression ... & that was just the flares.
T
Old November 22nd, 2003, 05:03 PM
Rick Carlisle
Rick Carlisle
Damn, not sure why, but this is confusing to me.
So, Troy, since I have a choice, I should go with 16x8 w/4 1/2" backspacing vs. same w/4" backspacing to keep the tire further inside the wheelwells??
Old November 22nd, 2003, 06:46 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Backspacing numbers are run from the mounting point of the wheel back towards the inside lip of the wheel. That means the lower the number, the farther it will stick out. The 4.5 will be .5 inches farther inside the 4in wheel. Hope that helps. Is there any reason why you do not want a wider stance??
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 22nd, 2003, 08:49 PM
Rick Carlisle
Rick Carlisle
Thank you David. I understand it now.
I like a wide stance but just don't want to get so wide the tires stick out past the wheelwells. While that may be what you want off-road, it is not the look I want for my daily driver. So I want as wide as I can get but still be inside the wheelwells. Just my preference.
Thanks again for all who responded.
Rick
Old November 22nd, 2003, 08:56 PM
tbmcneill
Guest
Posts: n/a
backspacing and offset are easy to get mixed up. here's a straightforward breakdown off a Porsche site (the only other truly great automobile in the world )....
http://www.hillmanimages.com/912/wheels.html
T
Old November 22nd, 2003, 09:19 PM
Rick Carlisle
Rick Carlisle
Troy, great site. I'm sure I'm not the only one who didn't get this.
I agree on the Porsche, by the way. I've had a 1972 911e, a 1969 911s and a 1962 356 Super 90. All great cars.
Rick
ac
new tire and wheel backspacing calculation... bharris Defender Technical Discussions 0 December 3rd, 2009 06:50 PM
15x10 4in Backspacing wheels Buckon37s For Sale - Parts 14 November 12th, 2005 02:06 PM
Wheels and backspacing Jase Defender Technical Discussions 3 February 14th, 2005 10:26 PM
Nato steel wheels with 2" backspacing Shane@EVS For Sale - Parts 5 November 30th, 2004 06:00 AM
Backspacing Question? Troys Defender Technical Discussions 15 October 1st, 2004 11:17 PM
