Backspacing - Defender Source
Old February 18th, 2010, 01:12 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Backspacing
Looking at 15x10 Allied Beadlocks with 37x13.5 iroks. Need 2 or 3 inch backspacing?
Old February 18th, 2010, 01:49 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I'd do 4...
Old February 18th, 2010, 02:50 PM
If you go with 4 or 5, so you won't need spacers. I run them with 35x12.5's and they do not rub.
Old February 18th, 2010, 07:55 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
I think you will get closer to 37" and it will look better with an 8" wide wheel, maybe 9".
Old February 19th, 2010, 12:31 PM
kiefffff's Avatar
kiefffff
Keith Rider
It won't balloon too much with only a 8" or 9" wheel?
Old February 19th, 2010, 12:37 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
my 35's look perfect on 15x8's with 4" backspacing.. Do they make a 15x9 w/ 4" bs???
Legend in My Own Mind.
Old February 19th, 2010, 01:06 PM
http://www.high-impact.net/wheels/ca...land_rover.htm
15x8 or 10 only. 2" or 3" BS is not possible. You get 2.5" or 4" to 9". 10" wide is a decent choice with 13.5" wheels. I would not listen to these guys with 35s.... 37s are a different story.... You need to find someone with 37s....
Old February 19th, 2010, 03:58 PM
bharris's Avatar
bharris
Brad Harris
There are other wheel manufacturers... ;-)
I believe Lane (mightymg) is running 3.5" of backspacing with 37s you might contact him if you want to know more... of course he's also running 17" wheels and only 12.5" wide...
Old February 19th, 2010, 05:53 PM
The OP asked about 15x10 Allied Beadlocks........
Old February 20th, 2010, 04:47 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Don't go with 10 in wide. 8 or 9in wide. It looks bad on 10, it lends the wheels to more damage, and you run the risk of losing inner beads.
Backspacing should be 4in max. 3.5 is better, 3in is even betterer, if you like to turn.
edit: If you are sold on those wheels (which I wouldn't be), I would take the 2.5 over the 4.125. Your scrub radius is going to suck balls though so if you are running a rover box expect very limited life.
Cheers
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 20th, 2010, 06:48 PM
madcowdungbeetle
Carter
I run 37's on 15x8 beadlocks with 4" bs. They do rub at full compression. Id recommend longer bump stops to combat this.
Do not run the 2.5" bs. They are reverse shelled.
Old February 20th, 2010, 08:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Whats wrong with that? If they are beadlocks from the get-go they must have found a way to overcome the outer usually inner lip issue. If they did not, then they are selling beadlocks that you couldn't mount a tire too. Which would be pretty funny.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 20th, 2010, 11:42 PM
madcowdungbeetle
Carter
I was thinking back to all the hilarious mounting issues people were having with the DIY beadlocks on reverse shell rims. Don't hold me accountable to anything I post on here from my cell phone while I'm at work.
Old February 22nd, 2010, 12:46 PM
kiefffff's Avatar
kiefffff
Keith Rider
Cheers
Thanks Buck. Going 8 inch wide makes sense. The backspace suggestions make sense too. Which beadlock wheel do you recommend? Trailready? Why not Allied?
Old February 22nd, 2010, 01:29 PM
Umm, yah. 33" tires hit the rear wheel well at full compression with stock bump stops...
Old February 22nd, 2010, 06:30 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
LR wierdness then because mine don't. They rub on the tailpipe hanger bracket of my Borla and on the raduis arms, but nothing on the wheel wells. 285/75 tires, Stock bump stops and standard springs.
Old February 23rd, 2010, 12:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
There is nothing wrong with Allied. I just don't like them for this application for two reasons, the backspacing is not ideal and the price. If you like a steel beadlock, you could get a cheap steely and do a weld on kit for $100 a tire for the best. If you don't want to do that, and it is a lot of work, I would see if they could make you a 3.75 backspaced wheel. Trailready is a great brand, but I don't know enough to tell you that it is right for what you are looking for. Kudos to you on a great tire choice. I hope you enjoy them.
Get power assist if you don't have it already.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 23rd, 2010, 12:31 PM
OK, but weld on beadlock are crap on the road. The allieds with the properly formed ring works much better. And the price is better than anything else. Not everyone has a trailer queen.....
Old February 25th, 2010, 09:58 PM
kiefffff's Avatar
kiefffff
Keith Rider
Thanks everyone. Going to go with 15x8 with 3.75 backspacing.
ac
15x10 4in Backspacing wheels Buckon37s For Sale - Parts 14 November 12th, 2005 02:06 PM
Wheels and backspacing Jase Defender Technical Discussions 3 February 14th, 2005 10:26 PM
Nato steel wheels with 2" backspacing Shane@EVS For Sale - Parts 5 November 30th, 2004 06:00 AM
Backspacing Question? Troys Defender Technical Discussions 15 October 1st, 2004 11:17 PM
backspacing Rick Carlisle Defender Technical Discussions 8 November 22nd, 2003 09:19 PM
