Backfire - Defender Source
Old May 13th, 2013, 11:53 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Backfire
I've searched and read 12+ posts on Backfire but they didn't address the issue I'm experiencing.
3.5L v8 with SU carbs and getting a backfire only when I turn off the engine. If the outside temp is above 80 seems like i dont have the issue but when its cool in the mornings or evenings it seems to happen more often. I've taken it for long two hour drives and short quick runs and same thing happens. Other than that it runs strong and no sputtering for problems. Just when I turn off the key. Pop!
Clay
Old May 13th, 2013, 12:35 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Read the plugs
Old May 13th, 2013, 12:40 PM
Run on?
Old May 13th, 2013, 12:58 PM
1of40's Avatar
1of40
1of40
Originally Posted by crown14 View Post
Read the plugs
As in proper gapping? I did replace the plugs a little while back but they were pre-gapped. Or at least I thought they were.
------ Follow up post added May 13th, 2013 12:59 PM ------
Originally Posted by Rocky View Post
Run on?
Engine run on? No.
Old May 13th, 2013, 01:14 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Is the timing set? Try advancing it a degree or two.
Old May 13th, 2013, 01:28 PM
crown14's Avatar
crown14
Verticalscrote
Engine run on? No.
No as in pull the plugs and have a look. The plugs can tell you a lot. Ive seen this happen before with one plug that had heavy deposits built up on it and it stayed hot enough to ignite unburnt fuel after shutoff- POP. If you happen to be running a little rich anyhow it's even easier for this to happen
I always check plug gap even on new plugs, I've seen 8 "pre gapped" plugs come out of the boxes with 8 different gaps...
Old May 13th, 2013, 01:31 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Are you backfiring out the exhaust or the intake?
Random Backfire jeffs90 Defender Technical Discussions 7 March 25th, 2010 06:34 PM
Backfire Andrew Vick Defender Technical Discussions 5 May 16th, 2008 08:38 AM
hot chicks and d90s mountainviewrover Misc. Chit-Chat 45 August 17th, 2007 07:27 PM
Backfire Zimbo76 Defender Technical Discussions 0 June 30th, 2004 06:48 PM
