Back window break light - Defender Source
Old October 27th, 2009, 08:57 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
What goop/glue is used for mounting the rear break window light unit to the glass?? (getting loose on one side)
Old October 27th, 2009, 09:17 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You have a light that tells you when your window is broken?
Old October 27th, 2009, 10:06 PM
Its right next to the change engine light.
The CHMSL is glued on?
Old October 27th, 2009, 10:24 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
On the new ones at least it is bolted on with two studs bonded to the glass.
Old October 27th, 2009, 10:34 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
plastic light unit -two mounting points-looks like a clear adhesive on the mounting tabs. Unit bolts on to tabs, one tab is loose.
Old October 27th, 2009, 10:52 PM
KKilo23's Avatar
KKilo23
Kenny
Same deal here... love to hear the fix.... tried using the same adhesive that one would use for rearview mirrors...no luck!
Old October 27th, 2009, 10:53 PM
ajh
Andrew J. Hutton
Try one of the adhesive epoxy putty things, one intended for sticking things together.
Old October 27th, 2009, 10:59 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
that epoxy putty is colored..hmm. Gonna have to check some stuff out. I'm thinking along the lines of a strong rubber based clear adhesive..
Old October 28th, 2009, 01:34 AM
Mirror adhesive, but you must clean the glass perfectly for it to work. use gasoline or other solvent after scraping with a razor blade.
ac, ht, window
Pick up back window rayfi Wanted 0 October 17th, 2008 02:38 PM
ST back window bar. draaronr Wanted 2 May 7th, 2008 10:44 PM
Window removal 1/2 way there Help!! paulb Defender Technical Discussions 2 May 11th, 2005 04:13 PM
Defender Check/Serive Engine Light - help! B-Kerr Defender Technical Discussions 8 May 9th, 2005 08:32 AM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
