B-pillar repair - Defender Source
Old December 8th, 2015, 09:42 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
B-pillar repair
Has anyone ever used a YRM B-pillar repair kit like pictured below? I'd love to get a visual of how to install this thing, as I need to order and do the same sort of fix on my 110.
Cheers!
-E
Old December 9th, 2015, 04:01 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
I just removed both the side frames on my 110. I was going to get the B pillar repair, but the sill frame is pretty rusty, excessive scaling in some of the seams. I could blast it and do a full rebuild on it, but for about $700 I am replacing the both side frames with brand new genuine ones. Going to have the e-coat removed and galvanize them. This way, the entire section is brand new and won't rust.
It was a toss up between repair or new, and with that cost to get completely new frames, it's hard to beat.
For the repair sections, you would have to cut away the bottom of the B pillar, grind off the weld on the sill and weld those new ones in, back of the pillar first, then the front. clean it up, fill it and paint. It's a lot of work either way.
Old December 9th, 2015, 07:12 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
I see this in my future . .
A-pillar..which repair panel? icnsltmfg Defender Technical Discussions 0 August 23rd, 2015 08:15 PM
C Hoop/Pillar Repair Possible or Solutions Funtogun Defender Technical Discussions 11 May 14th, 2015 04:22 PM
ST b-pillar c-pillar and cantrails dave_lucas Wanted 7 May 12th, 2010 11:39 AM
A Pillar Cage and B pillar seat belt holders CDeWan For Sale - Parts 14 December 24th, 2009 07:18 PM
B-Pillar Picture Required CDN22 Defender Technical Discussions 11 May 11th, 2004 11:48 PM
