B-Pillar Picture Required - Defender Source
Old May 2nd, 2004, 09:15 PM
CDN22's Avatar
CDN22
Ken
1994 D90
I'm trying to put Humpty-Rover back together and it's turning out like Franken-Rover...
What would really be appreciated is a photo of a 94 D90 ST where the external safari cage mounts to the b-pillar minus rollbar padding.
A previous owner removed the horns for a HT conversion and left me with somewhat of a puzzle going back to ST. I have about an inch and a half gap to the pillar and no gouge/grind marks where apparently the "horns" should connect if I connect everything to the external cage. There are grind marks below on the pillar!??!
Any thoughts?
Thanks.
Old May 3rd, 2004, 01:15 AM
tbmcneill
Guest
Posts: n/a
gotta pic?
Old May 3rd, 2004, 10:14 AM
More then Happy to take a pic, but I am not sure what you want a pic of Are you talking about right behind the drivers seat?
Old May 3rd, 2004, 11:34 AM
tbmcneill
Guest
Posts: n/a
the grind marks below the pillar? The ST cages should have horns that come off the b-pillar similiar to the a-pillar on a HT. If the horns on the b-pillar were ground off, some new ones will probably have to welded on.
i don't understand the grind marks below the pillar, though.
Old May 4th, 2004, 04:43 PM
CDN22's Avatar
CDN22
Ken
1994 D90
Michael, you post too fast.
It appears in the test photo that the b-pillar is somewhat shorter than it should be which would explain why the gring marks are so low!??!
Old May 4th, 2004, 04:47 PM
HMMM, You show me yours, i show you mine.
Old May 4th, 2004, 06:04 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Here is a SW rollbar and its connection point:
http://www.defendersource.com/mod/sw...i-DCP_0558.JPG
Compaire to a ST rollbar that had its forward part cut off as well but not as bad as yours:
http://www.defendersource.com/mod/sw...i-DCP_0594.JPG
looking at your picture, the fellow stripped and cut the ST foam and connection point way back rather than buying a real SW roll bar. Looks like you will need to weld an extention to complete it.
Chris von C
[/size]
Old May 4th, 2004, 09:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
the problem is that the foam is now missing and you will not be able to fit a soft top with it like that. Your bes bet is to find a used bar and get rid of yours. here is one for sale and they will take less then what its there for.. http://cgi.ebay.com/ebaymotors/ws/eB...category=42611
Legend in My Own Mind.
Old May 8th, 2004, 07:20 PM
CDN22's Avatar
CDN22
Ken
1994 D90
Thanks everyone. I have the foam pieces so that's one hassle I won't have to deal with. The puzzling bit now is the rear roll bar does not align with the front.
www.d-90.com/forum/attachment.php?=&postid=13523
Old May 8th, 2004, 09:20 PM
tbmcneill
Guest
Posts: n/a
The b-pillar actually looks like one from a SW ....??? ... which would explain why things aren't lining up.
T
Old May 8th, 2004, 09:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
your b-pillar is totally wrong. I think Troy is right with the SW theory
Old May 11th, 2004, 11:48 PM
CDN22's Avatar
CDN22
Ken
1994 D90
I just 'found' two lengths cut roll cage with the soft top - roughly 2 inches has been cut from the bar.
Would welding an appropriate spacer result in any weaknesses in the strength of the cage?
Thanks again!
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
Picture of Door Check Strap mgrgpg Defender Technical Discussions 6 October 24th, 2005 08:39 AM
Picture needed! TwisteD90 Defender Technical Discussions 7 October 2nd, 2005 05:01 PM
B pillar attachments redrover Defender Technical Discussions 6 February 8th, 2005 08:41 AM
can't post a picture Campbell Support & Suggestions 7 June 3rd, 2004 07:44 AM
