Axles with a twist - Defender Source
Old March 14th, 2013, 07:34 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Axles with a twist
Been going through the 90 to get it up and going for this summer. And what do I find .
ID:	68102   Click image for larger version
85 D110 3.5 3 DR
Old March 14th, 2013, 07:52 AM
bossman429's Avatar
bossman429
Adrian
1988 90
I've years axles can twist 720 degrees before breaking. Not sure if that's true but if it is that's crazy
------ Follow up post added March 14th, 2013 07:52 AM ------
Damn iPhone. Years = heard
Old March 14th, 2013, 08:07 AM
The Dro
Dro
1988 Ninety
Are they stock?
Old March 14th, 2013, 09:28 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Impressive!
Semper Fi!
Old March 14th, 2013, 09:47 AM
The Dro
Dro
1988 Ninety
It looks like it's time to call Ashcroft
Old March 14th, 2013, 09:52 AM
87 D110 (Ruby)
^^^What you don't have any Pedro^^^ ?????
Old March 14th, 2013, 10:53 AM
Frankly, I would still run them if they are aftermarket. That is no where close to breaking twist.
Old March 14th, 2013, 11:24 AM
Wolf Fabrication
Sterling Archer
'08 D3
I agree, but carry a spare. Too bad you can't swap sides!
Semper Fi!
Old March 14th, 2013, 11:42 AM
Rovertracks?
Old March 14th, 2013, 12:03 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I have a different sensitivity to known defects and would replace it. It would then become a spare.
1970 SIIA 88, Sold
Old March 14th, 2013, 12:40 PM
Those are spares quality.
Old March 14th, 2013, 12:45 PM
What in God's name you doing out in the Yukon?
Mark Kellgren
KM4BOR
Old March 14th, 2013, 01:19 PM
They don't break until well over one complete rotation (usually around two complete rotations). Go over to pirate4x4 and see. People put sharpie marks along the length and they end up looking like barber poles.
Old March 14th, 2013, 01:22 PM
For stock axles, yes. These are certainly not stock.
Old March 14th, 2013, 01:31 PM
Stock axles are actually more bittle and are less able to twist. If you look at the metalurgy of 4340 you will see. Lots of stuff out there.
Old March 14th, 2013, 01:51 PM
These look like Rovertracks to me, so not 4340.
I'm not sure what makes you think stock axles are brittle. All testing I've seen shows otherwise....
Ashcroft tests: http://www.ashcroft-transmissions.co...0halfshaft.JPG Well over 2 full turns on a stock rear shaft. 246 degrees for the 4340 shaft.
Old March 14th, 2013, 02:10 PM
Interesting.
I stand corrected.
Old March 14th, 2013, 02:14 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Hey Guys
These are indeed Rovertracks axles, I have pulled them out of the 90 and put in a set of Maxi Drives with GBR drive flanges. Not sure how they will hold up to abuse but we will see. The maxi drives are older from 04 05 time frame have lived a pretty easy life in a 94 Disco. Side by side the Rovertracks are larger than the Maxidrive units, the maxis tapper after the splines and Rovertracks are same diameter all the to the flange.
85 D110 3.5 3 DR
Old March 14th, 2013, 02:24 PM
As long as the wasted area is 30.1 mm or larger, it will still be stronger than the splined area. If you start killing those, you need to get to a larger spline size....
Old March 14th, 2013, 02:33 PM
and don't use your Rover for Grizzly wrangling anymore.
Mark Kellgren
KM4BOR
axle
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
Who makes the strogest axles? Scott 9835 Misc. Chit-Chat 21 December 21st, 2005 01:02 AM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
GBR 4:10/ARB 3rds and Axles WhiteD90 For Sale - Parts 6 December 2nd, 2003 03:00 PM
