Axles with a twist - Page 2 - Defender Source
Old March 14th, 2013, 02:38 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Originally Posted by Overlander View Post
and don't use your Rover for Grizzly wrangling anymore.
Haha I run from those things ,
------ Follow up post added March 14th, 2013 10:39 AM ------
Well at least we know the ARBs and GBR gears are strong as well.
85 D110 3.5 3 DR
Old March 14th, 2013, 02:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I was wondering how you twisted up RovingTrack axle shafts then saw you are on 36" Swampers. Although they don't look too badly twisted.
Wish I could find the picture of the 30 spline Toy vs a stock 24 spline LR axle - pretty good sized difference between the 2. I'm hoping I should be fine with the 30 spline and 35"s.
Old March 14th, 2013, 03:02 PM
aka rover's Avatar
aka rover
ed angel
95 D90
I am now running 37" BFGs now lighter and less traction so should be better off now. I am impressed how much abuse the drivetrain CAN take on a rover if its left light weight. Im sure something would have broke if it was a loaded down Disco
So you guys think theses axles are still usable?
I have a friend building a rangie on 33" tires his is a automatic 3.9 ltr stock. Hes still running 10 spline so these have to be stronger even twisted than 10 splines.
85 D110 3.5 3 DR
Old March 14th, 2013, 10:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Yeah Swampers can run pretty heavy especially compared to a BFG. The might be close in OD as well.
I would think the axle shafts would be fine on a 33" tired rig but you might want to check with the guys on Pirate. They have way more background on the subject than I do.
Old March 24th, 2013, 03:43 AM
CDeWan
Clay DeWan
5.3L beastie
axles
I think they still are. I bought a used set of front GBRs from Ron and they had some twisting in them. I think it would take a hell of a lot of abuse to loose an aftermarket axle. Did you put new drive flanges on the end of those bad boys?
Generally question to all, how often do the drive flanges go out/strip out etc?
Old March 24th, 2013, 09:28 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Hey,
it's been a long time since I mashed the pedal while on my 36" Swampers,
but I always found them relatively light (bias) for the tire being...especially compared to radial ones (by feeling my SSRs seem heavier).
Did you weight or check those 37" (KM2?) on the BF website?
And post a pic
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 24th, 2013, 01:19 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks Clay
I will let him know the axles may work out for him. I did put GBR drive flanges on the Maxi Drives. Not sure On how often the flanges go my stock front flanges started getting some slop in them and I replaced them with after markets and they fit nice and snug now.
Originally Posted by Cube II View Post
Hey,
And post a pic
I didn't weigh them so im going by what the difference it made in over all performance and how they felt during the tire swap lifting them seemed the BFGs to be lighter.
The 36" TSLs where on a 15x10" steel wheel and the 37s are on a 17" beadlock.
85 D110 3.5 3 DR
Old March 24th, 2013, 01:20 PM
aka rover's Avatar
aka rover
ed angel
95 D90
A crappy cell pic but its not in the drive
85 D110 3.5 3 DR
Old March 24th, 2013, 01:38 PM
CDeWan
Clay DeWan
5.3L beastie
rims
Ed,
What kind of rims/make are those I am in the market to go with some 35s on beadlocks now that I have the 3 inch lift in.
Old March 24th, 2013, 01:49 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Walker Evans beadlocks, they are pretty nice and balanced out great.
85 D110 3.5 3 DR
Old March 24th, 2013, 07:29 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The sure way to stop the axle slop is to pull the flange and axle apart and clean them well and then beat the flange onto the shaft as far as it will go and then tig the backside and under the dust cap and reinstall! I've done this on multiple sets and even did a few for Bill when people were returning them due to slop on the splines. On the other hand...you can always sqeeze a set of Ian's "Force 9's" under you rig. Good luck!
axle
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
Who makes the strogest axles? Scott 9835 Misc. Chit-Chat 21 December 21st, 2005 01:02 AM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
GBR 4:10/ARB 3rds and Axles WhiteD90 For Sale - Parts 6 December 2nd, 2003 03:00 PM
