Axles - Defender Source
Old May 3rd, 2009, 06:50 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Axles
I thought I had this all figured out until the the last Axel thread.
1985 90 with rear drums
Got a 1997 Disco donor truck.
Questions
1) Will the rear axle(calipers and all) work , with the stock front?
2) Will the front axle work if I want to swap them both?
Old May 3rd, 2009, 06:55 PM
1. Yes, BUT the brake lines are different though so you would have to use your single input T-junction not the disco I two input one and a disco does not have the BOGE unit, but I doubt your 90 has it either. Also, I am not sure of the year cut off, but some early trucks have one shock on the front of the axle and one on the back so to swap a DI you would need to drill three holes and move the upper shock mount on one side. This assumes that it has a normal pinion flange, not the rotoflex (otherwise you would have to swap the normal flange onto it).
2. Yes, I can't think of anything problematic off the top of my head (maybe brake lines again) other than you would want to use your steering parts because the disco damper is mounted behind the axle and the disco is set up for the pitman arm that has the hole in it rather than the built in ball joint.
Old May 3rd, 2009, 07:02 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
thanks!
Old May 3rd, 2009, 07:18 PM
No problem.
Old May 4th, 2009, 08:19 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Tom, I did the same thing on my Silver truck.. It has a 96 disco rear assemble.
Legend in My Own Mind.
Old May 4th, 2009, 08:31 AM
I also put a 97 disco rear under my '84. I put the calipers from the disco on the 84's front axle. which I think may have been a later axle. The 97 axle you have uses wider radius arms, so you will need those if you want to use it.
Old May 4th, 2009, 11:20 AM
The point Randy and Dave are making is that you want the whole assembly.
Old May 4th, 2009, 07:28 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Do I need a different Brake Master cylinder?
Old May 4th, 2009, 08:44 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I think the stock one will be fine.. I ran the stock one on the series 88 with the disk brake setup.. On my 90 I changed the entire brake setup to the NAS 90 configuration.
Old May 5th, 2009, 09:36 AM
I did not. Like I said, I put the disco axle in and only changed the Tee on top of the axle where flex goes in. On the front I just swapped over the disco calipers since my Defender ones were dodgy. The disco front calipers were identical to the defender ones. I did not change any other parts in the brake system. The braking is noticeably improved, from very good to "i can't believe this is a land rover"
axle
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
Who makes the strogest axles? Scott 9835 Misc. Chit-Chat 21 December 21st, 2005 01:02 AM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
GBR 4:10/ARB 3rds and Axles WhiteD90 For Sale - Parts 6 December 2nd, 2003 03:00 PM
