Axle Vendor Recommendation? - Page 3 - Defender Source
Old June 15th, 2012, 04:39 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Originally Posted by Jake1996d1 View Post
I hate to say it but it is either not the diff but.. something else? OR you need to have somebody else set up your diffs. I find it strange that it is happening with different truetracs and gear sets. Something else isnt right here. I look forward to the next video. If you could just bring your truck over to my place I could figure it out
Trust me, I have started to take vacation from work and just drive the damn thing to Bill's shop in Salt Lake 10 times over.
With some luck, a detailed video (with several video cameras), and good audio recording on multiple points, it will be "just like the real thing."
Baby steps. It can't break forever.
Old June 21st, 2012, 03:18 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Video complete!
I'll get it posted to YouTube in about 6 hours (when I get back home).
Old June 21st, 2012, 09:58 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Old June 21st, 2012, 10:44 PM
Have you actually checked that your axle is straight?
Old June 21st, 2012, 10:50 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Not personally. No clue how. The LR Tech that installed the last diff told me he gave them a once over and that they slid right in with no binding.
That said... I'll know, definitively, that they're straight when I put the new one's in a few days from now.
But if it was the axles, why didn't the 1st or 2nd diff makes all this noise? Perhaps they've bent because of all the strain? Any thoughts welcome.
Old June 22nd, 2012, 11:11 AM
Of course they will slide in fine. Look at the drive member flange before bolting and see if it is parallel. Put a digital level on the axle flanges.
Old June 22nd, 2012, 03:17 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
I'll do the check and get back to you. Any other input on the noises heard in the video?
Old June 22nd, 2012, 03:52 PM
No idea. Have seen a few True Tracs, never noticed any noise. Obviously turning on pavement with the center diff locked is nasty at the best of times.
Old June 22nd, 2012, 06:30 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea I agree with driving on pavement with CDL locked thats asking for something to blow up. Maybe if you slam on the gas you will be able to figure out what the real problem is
Since it happens mostly when one wheel is turning more than the other I would believe it is the carrier (truetrac). I would pull the diff and take it to a different diff shop and get an opinion. You could also see if Eaton has any sort of "certified" diff mechanics in your area that can take the truetrac apart and inspect it.
Have you tested the truetrac on something slick to see if it still works like it should?
axle
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
» Defender Registry
Oliver
IvanKV
blondy
01CRF10
Add your Defender
