Axle swap 90 and 110 101 - Defender Source
Old November 21st, 2010, 07:06 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
2 part Question:
If I put a Disco axle in the front end of my 90, can I use the rotor and calipers from the old 90 Axle? Or should I just keep the Disco calipers and rotors?
2nd part:
Can I use the old 90 axle parts to convert my RHD 110 front axle to LHD?
Many thanks
Old November 21st, 2010, 10:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
That's what I was hoping,
Thanks.
Old November 22nd, 2010, 12:08 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
I put my disco axle under my 90, and just swapped the rotors over and it worked great
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old November 22nd, 2010, 12:35 PM
Tom,
Your D90 axle should have the same calipers (or similar) as a disco I. Only the later D90s got the wider calipers for vented rotors.
roverguy sells two calipers, two rotors and pads for just over $400.
As far as using the D90 parts to convert the 110 front, the main thing you need to look at it is to make sure the swivel balls have the same number of bolts to the axle case. The early ones have six and the later ones have seven (IIRC I have never looked at an early one and noticed).
Ron
Old November 22nd, 2010, 07:43 PM
triathlon616
sage mount
1995 defender 90
I may buy a 1995 d-90. The front axle is missing the rear axle is still intact. What axle should i use for the front disco1?
Old November 22nd, 2010, 07:54 PM
Yes, a D1 axle will work and fit perfectly..
Old November 22nd, 2010, 08:27 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Keep in mind that if you are using an axle set up from a disco with ABS the top pin on the swivel ball will have a hole in it for the ABS sensor.
Land Rover 110
110, 90, axle
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
10 Spline Axle Parts Series / 90 / 110 Wolf Fabrication For Sale - Parts 0 April 6th, 2010 06:25 AM
Lots of various 90 and 110 parts for sale Tyler Wirken For Sale - Parts 33 September 25th, 2009 08:35 AM
