Axle swap - Defender Source
Old May 19th, 2015, 05:49 PM
Jadam76's Avatar
Jadam76
Adam Reynolds
1984 D90
Axle swap
I am wanting to swap out my front axle from my 84 ROW 90 with one from a 93 RRC. It will allow me to keep it on the road while rebuilding the original one. I can't seem to find a solid answer on if it will fit without much modification. Will it fit and if so what will be required to do so.
Old May 19th, 2015, 06:02 PM
93 Classic may have a different width on the bushings. If you swap you should swap the radius arms along with. Why not a 94 and then you'll have 24 spline axles
Old May 19th, 2015, 06:13 PM
Jadam76's Avatar
Jadam76
Adam Reynolds
1984 D90
The plan was a temporary swap until I rebuild the original one. I found the 93 RRC axle for cheap and thought it would work with minimal modification. It was suggested on another forum to swap over the rotors and calipers. Not sure how simple that is though.
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
Axle swap 90 and 110 101 tomaco1 Defender Technical Discussions 6 November 22nd, 2010 08:27 PM
Axle Swap w/Disco I founD90 Defender Technical Discussions 24 June 17th, 2010 11:30 AM
Front Axle Swap RiftRover Defender Technical Discussions 16 April 30th, 2009 11:42 PM
Front axle swap flippedrover Defender Technical Discussions 15 October 4th, 2007 08:54 AM
