Axle Pressure and Too Much Fluid - Defender Source
Old December 30th, 2009, 07:32 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Just throwing this out there for discussion.
I was checking both axle fluids for the first time yesterday and when I pulled the fill plugs air hissed out. Fine, that means blocked breathers and explains the drips under my diffs. BUT, fluid actually GUSHED out! The front must have been aleast 12-16oz. The only thing I can think of is that water got in, sank to the bottom, and then forced out the gear oil. But I am not sure how this could happen if both my breathers were clogged shut.
Any thoughts? Were the wee little lephrechauns at play under my rig?
Semper Fi!
Old December 30th, 2009, 07:51 AM
Cirbo's Avatar
Cirbo
Jim C.
Did the oil look milky? What are you running in your swivel ball housings?
Certified JB-Welder
Old December 30th, 2009, 07:53 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
YEah, check for contamination and remove the breathers to check them as well.
Legend in My Own Mind.
Old December 30th, 2009, 07:55 AM
Wolf Fabrication
Sterling Archer
'08 D3
No, the fluid was fine. Didn't stink and was not milky. I already removed and cleaned the breathers. Just perplexed!
Semper Fi!
Old December 30th, 2009, 08:23 AM
When a vehicle is driven through or parked/stuck whatever in axle-deep water it is not uncommon for them to draw in water through any opening, i.e, leaky gaskets or around the stub axles or diff pinion. Gear oil doesn't contain emulsifiers like motor oil does so the water doesn't always mix, or maybe can separate over time (not really sure but I have seen it mix and I have seen it not mix too). Sometimes you can crack the drain plug carefully without removing it and let the water drain. Somehow I doubt that is your problem though. Anyway if the oil looks good and there's no water at the bottom, just let it drain to the level of the fill plug and be done with it.
Old December 30th, 2009, 08:45 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The previous owner might have convereted it to wet bearings which necessitates overfilling the diffs.
Old December 30th, 2009, 09:40 AM
Wolf Fabrication
Sterling Archer
'08 D3
Well, I have Disco 1 axles if that means anything.
Semper Fi!
Old December 30th, 2009, 09:54 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Just search "wet bearings" here and you will know what I mean.
Old December 30th, 2009, 10:11 AM
Wolf Fabrication
Sterling Archer
'08 D3
Ahhh, makes sense now. Anyone know if Disco 1s had wet seals? Seems kinda hokie.
Semper Fi!
Old December 30th, 2009, 12:15 PM
Actually overfilling is not necessary. The fill/level plugs are over the center of the axle tube and the hubs will get plenty of oil on a regular fill. Series land rover axles come this way from the factory. Nothing hokie about it, the bearings are huge and do just fine running in oil.
Old December 30th, 2009, 01:03 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Early 90's &110's came that way too. My 110 has just over 200.000 miles on it 130.000 which I've put on and no bearing trouble, touch wood.
Mike Hammond
Old December 30th, 2009, 01:09 PM
Wolf Fabrication
Sterling Archer
'08 D3
See, now that explanation makes sense. That's why "overfilling" didn't make sense to me and sounded hokie. If LR wanted you to overfill, you figure they'd raise the fill plug!
Semper Fi!
Old December 30th, 2009, 03:26 PM
That would be unretarded and land rover is retarded.
axle
