axle knuckle question - Defender Source
Old June 11th, 2009, 02:44 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
I just bought my Defender and the front axle has a very shiny peice of metal right where the knuckle is (looks like the knuckle rotates on it or something). Is there supposed to be a boot on these? And if so, where could i get a pair?
http://i20.photobucket.com/albums/b2...ep100/axle.jpg
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
thats the way its made.
Old June 11th, 2009, 02:54 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Series rovers had leather boots over them but they hide any issues that might be occuring and the rubber seals do a good job of protecting the bits inside.
Old June 11th, 2009, 03:05 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
ok. So it sounds like this is normal. I always worry when I see shiny metal like that.
Old June 11th, 2009, 03:15 PM
landrovered
S. Smith
When the metal is pitted then you should worry.
Old June 11th, 2009, 03:20 PM
its the stuff inside the shiny thing that is important.
Old June 11th, 2009, 03:34 PM
I would be more concerned as to why someone painted your axle casing silver.
Old June 11th, 2009, 05:35 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
For the bling bling!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 11th, 2009, 05:51 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You can get leather gaiters for those joints (for defenders), although i had a set on my old 90, and they split, I never noticed, so they let in all the poo and mud, and mullered my chrome ball and oil seal.
Old June 12th, 2009, 08:14 AM
David, just so you know, the knuckle as you know it is inside of that. What you have is perfectly normal - just do regular maintenance like change the grease/oil in them and you will be fine.
hth
charles
Old June 12th, 2009, 09:34 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Very helpful. Thanks everyone!
Old June 12th, 2009, 09:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by JSBriggs
Yea, but its got nothing on gun metal silver with silver flake clear coat!
-Jeff
You cross posting stud!
I'll see that silver bling and RAISE you!!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 16th, 2009, 06:53 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For future reference the chrome bit is called the swivel ball, what it goes in to, where the large oil seal is, is called the swivel housing. The swivel ball is held in the swivel housing top and bottom by swivel pins.
Yes, you can get leather gaiters for them, and if saturated well with petroleum jelly before fitting will last a long time. I've found they are good in snow country to keep from packing snow on full turns and damaging the swivel oil seal. That said, I don't know anyone in the US who sells them. I got mine from PA Blanchard in the UK.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
axle
Front axle question... Grover Defender Technical Discussions 21 November 11th, 2009 11:33 AM
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
helical gears and Axle question CDeWan Defender Technical Discussions 3 April 30th, 2008 10:56 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
