axle housing serial number - Defender Source
Old November 22nd, 2008, 09:15 PM
can anyone point me to where to look on my Salisbury rear axle housing for the serial number ?
Need to get that number to figure out which drive flanges I need (worn out).
Old November 22nd, 2008, 09:20 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Prob cheaper to just get a set of HD rear axles from rover tracks or is your truck have drums in the rear?
Legend in My Own Mind.
Old November 22nd, 2008, 09:52 PM
My truck has been retrofitted with a disk brake rear and the flange part numbers changed a couple of times over the years. Need to be sure to get the correct ones. Looked breifly and couldn't find the serial number on the rear-found it easily on the front.
Old November 23rd, 2008, 07:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
the standard housings have it stamped on the tube. should be on the long side and facing the rear. That is if they are the same as the d-90 rear axle
Old November 23rd, 2008, 12:09 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
The number should be something like 21SXXXX.
axle
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
telling the build year by the engine serial number cdb Defender Technical Discussions 2 August 16th, 2006 08:45 AM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
axle housing redrover Defender Technical Discussions 5 June 19th, 2004 02:14 AM
D90 rear axle housing! TwisteD90 For Sale - Parts 0 January 13th, 2004 07:55 PM
