Axle Code - Defender Source
Old August 25th, 2016, 10:35 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Axle Code
I'm in the process of replacing swivel balls on my '89 Ninety p/u...I'm told that there are different swivel balls for different axles. Of course my axle is corroded enough that I cannot see an axle code. Does anyone know another way to determine the axle code or is there another way to determine which swivel ball I need?
Old August 25th, 2016, 10:42 AM
AFAIK, it is all about the bearings and there are two versions.
The early ones have a swivel pin on top and bearing on bottom. Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Later has a bearing on top and bottom. Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Old August 25th, 2016, 10:50 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Thanks John, figured it was something simple but didn't have a diagram of the newer style...mine are the older stlye w/ single bearing. Thanks again.
axle
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
