Axel end mods - Defender Source
Old January 26th, 2008, 03:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Axel end mods
How does one modify the axel ends of an 1985 L/R 90 to fit allows on the truck? The "mushroom caps" as someone called them stick out to far to get the center cap on. Other than spacers, what are my options?
Tom
Old January 27th, 2008, 10:39 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is there a quick fix?
Old January 27th, 2008, 12:21 PM
Get the spacers... I have them on my ST and I really like them.
Old January 27th, 2008, 12:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
which do you have?
Old January 27th, 2008, 12:38 PM
They are 1 1/4 inch aluminum, I do not remember the brand. I will see what I can dig up.
Old January 27th, 2008, 01:05 PM
Cant you just change out the drive flanges or whatever? I havent done it, but I'm curious as to what the difference is.
Old January 27th, 2008, 06:28 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I think if you change the flanges you will have to change the axles. But you may be running 10 spline and you may have to change more...
a picture speaks a thousand words.
Old January 27th, 2008, 06:34 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
just the dust caps
I was wondering if I could switch out the dust caps to shorter ones? I have the taller ones ath the moment, on an 1985 LR 90.
Old January 27th, 2008, 06:48 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
1985 had 10 spline rear axles. Different flanges.. You would have to change to 24 spline diffs and later shafts. Or get the spacers..
Legend in My Own Mind.
Old January 27th, 2008, 07:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Take off the rubber caps and weld on new caps. Takes away the really pointless rubber caps and might allow you to run the rims.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 27th, 2008, 11:07 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
You may be able to use the 10-spline axles from a 87-88 Range Rover Classsic in the rear - not sure about the fronts.
Old January 28th, 2008, 12:08 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Pull one of the axles and find out what you have first. Don't know if your truck is a ROW or a MOD. If its a mod there is a very good chance that it has 24 spline HD axles already.
Old January 28th, 2008, 10:06 PM
I'm just guessing but I imagine they sell center caps for the alloys that bulge out like the rubber caps. Spacers are way expensive.
But more importantly why alloys?
charles
Old January 29th, 2008, 10:22 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Yeah the spacers are way too expensive. Why can't someone make a more affordable one?
Old January 31st, 2008, 10:59 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Tom you have a few choices...
1) axle should be a 10 Spline outer so you can fit axles from an early discovery or RRC
they have the drive shaft welded to the drive member - no leaky or lost caps.!
2) buy slim HD drive flanges that have screw on caps.
3) if you want to fit alloys buy ones for the axle, compomotive make a set for the early 90 axle
the other issue apart form the center cap is the length of the wheel stud, on cars with alloys there is a bar ( - ) in the end of the stud to show it is suitable for alloys eg the stud is longer.
4) fit spacers but buy good ones, personally I don't like them but if needs must get good quality ones with a makers name on them
On my '85 90 i fitted disco shafts on the rear as it eliminates the clunk from worn drive members
and i had a pair in the garage..
you can do the same thing on the front.
Regards
Gren
HI Again tom sorry missed the picture. the shorter caps are for the later axles but will fit with a little help from a mallet ;-) however they tend to split or pop off when old
Gren
Old January 31st, 2008, 11:09 AM
Why don't you just get a complete rear axle from a discovery 1 or mid-1993 and up RRC?
Should sell for $150 or so and you would get discs and everything, heck someone gave me all the axles and stuff from an 1987 RRC.
mod
front end moves jimmy salmon Defender Technical Discussions 20 September 18th, 2005 04:40 PM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
Half Roll Cage End Caps boshea Wanted 4 July 14th, 2004 04:05 AM
