Average Engine running temp, '04 4.6 V8 - Defender Source
Old June 22nd, 2014, 08:42 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Hello All,
I'm trying to chase down a potential running hot problem and was wondering what you guys had for an average running temp on the Rover V8. 2004 4.6, usually between 200-215 with 221 as the peak on a very warm day in a hilly area. As soon as I reached the crest (and it shifted, it dropped back to ~208). I feel like this is on the high side of normal but wanted to see what the community thought.
Initially there was air in the system which I've since purged, next I'm putting in the lower temp thermostat (as recommended by a board member). But I wanted to make sure there's nothing I'm missing if I'm going to swap cars with my wife to drive the little ones around...
Any ideas?
Pics via Torque App and a bluetooth OBDII reader, so yes it relies on the factory sensor.
ID:	97357   Click image for larger version
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 22nd, 2014, 08:49 PM
jafir's Avatar
jafir
Jafir Elkurd
How fast were you going?
Those temps are a little high. I'd think fan clutch.
Old June 22nd, 2014, 08:50 PM
Is it holding pressure?
Old June 22nd, 2014, 09:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
25-30 in the hilly parts the other day. Definitely not highway speeds if that's what you were asking. Fan clutch could be suspect, but it does spin freely with a bit of resistance both directions when cold.
Yes it holds pressure, no leaks that I see.
~2008 GTI TSI
Old June 22nd, 2014, 09:17 PM
jafir's Avatar
jafir
Jafir Elkurd
Yep, that's what I wanted to know. I assume you were moving faster after you crested the hill?
My guess is that the clutch doesn't lock up enough after it gets warm, so at lower speeds you aren't moving enough air.
Old June 22nd, 2014, 09:19 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
A bit faster. I'd say just less load. It's worth noting this was with 5 people in the car. By myself it's a few measurable degrees less.
------ Follow up post added June 22nd, 2014 09:26 PM ------
In retrospect it definitely had a good amount of air in it which caused my initial concern. I'm just trying to lock it up after fixing that part of the issue.
~2008 GTI TSI
Old June 22nd, 2014, 09:30 PM
definitely change the fan clutch. then see how it is. made a huge difference for me.
Old June 22nd, 2014, 09:34 PM
Have you flushed the radiator?
Have you done a pressure test ... Sometimes you only get to see a fine mist leak under pressure that's would evaporate before you see it when running.
If the fan locks up then chances are it's not the root cause ... You want to make sure everything is good before changing something that could mask the problem.
Do you know why you lost fluid in the first place?
Old June 22nd, 2014, 09:54 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Haven't dug into it more than topping off the fluid and purging the air yet. I think there was air in the system since I've had it. There was a replacement motor put in about a month before I took ownership. I have a feeling that it wasn't purged correctly since install it just took this long for me to notice.
~2008 GTI TSI
Old June 22nd, 2014, 10:35 PM
New or used motor?
Old June 22nd, 2014, 10:44 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Used, 70k or so.
~2008 GTI TSI
Old June 23rd, 2014, 01:23 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Those numbers look fine to me. I regularly monitor cars while driving during diagnostics. It's not unusual for these cars to run 225 on the highway. The lower temp thermostat will probably drop it a few degrees, but I wouldn't be unduly concerned.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 23rd, 2014, 01:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
related question, I've heard BMW pink (DexCool) or flush and switch to green. What's the consensus?
~2008 GTI TSI
Old June 23rd, 2014, 01:29 PM
I suggest green. Flush it thoroughly.
Old June 23rd, 2014, 01:45 PM
Also fit the TD5 thermostat so it runs cooler. There is zero margin for error or spikes running at those temps.
Old June 24th, 2014, 09:55 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
New (180) t-stat came in today, fitting tomorrow.
~2008 GTI TSI
Old June 24th, 2014, 09:58 AM
jafir's Avatar
jafir
Jafir Elkurd
I had my ultra gauge in my acura tl and my lr3 and very rarely would either get to 200. Most of the time they stayed around 196. Never as high as 210.
Old June 26th, 2014, 06:44 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Lower temp t-stat installed, coolant totally flushed out and replaced with green coolant (no gunk that was found). New equilibrium temp appears to be about 200. Highest I got it was 204 after a quick highway run. Immediately dropped once I let off the throttle.
~2008 GTI TSI
engine, v8
Maximum number of miles (on average) for an original v8 (gas) engine? egor Defender Technical Discussions 11 June 6th, 2012 08:07 AM
300tdi top speed average? 323jamie Defender Technical Discussions 82 March 11th, 2012 09:46 PM
Not Your Average Floor Mat Question James Pierce Defender Technical Discussions 0 September 28th, 2010 09:41 AM
Average Wait for Rockware Bumper? cellulararrest Defender Technical Discussions 18 January 30th, 2008 08:22 PM
average cost per year? 1000kva Misc. Chit-Chat 8 September 25th, 2006 11:08 PM
