Auxillary heat - Defender Source
Old July 22nd, 2016, 07:39 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Auxillary heat
What sort of systems have others integrated into their builds to supplement the heat? I want to heat the rear of my 110 TDi a little better this winter.....
Email is
Same place, new dogs.
Old July 22nd, 2016, 09:59 AM
GunnyUSMC
Eric
1991 Defender 90 200TDI
A lot of the Brits use either Eberspacher or Webasto. Sorry, I don't have any personal experience with them. Just have seen them installed.
Old July 22nd, 2016, 10:56 AM
Eber and Webasto are both great. you'll get all the heat you want with the air heater versions if heating the cabin is what you're after. The alternative is adding on an aux heater with it's own fan, which ties into your heater lines.
those are pretty much your two options. There is a 3rd option, which is to fill your cabin with beagles, but I am not a proponent of that course of action.
Mark Kellgren
KM4BOR
Old July 25th, 2016, 02:46 PM
Roverlab
Trevor Griffiths
Swiss Mountain dog is shedding enough fur for a blanket. Problem solved.
Thinking I'll go with a fuel fired unit; opinions on air vs water?
Email is
Old July 25th, 2016, 03:44 PM
If you want to heat the cab, you need air. Water is for heating the engine when it is not running.
Old July 25th, 2016, 03:45 PM
BlackField's Avatar
BlackField
Oscar
D110
I've discussed this before with great input from the usual suspects:
http://www.defendersource.com/forum/...tdi-59741.html
Most of this is currently installed on the truck. Maybe this year it will be finished by winter.
Old July 25th, 2016, 03:54 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Do a search on defender2.net. Wacky Brits have this covered.
KGH - “Stinky LR diesel” Defender Snob
Old July 25th, 2016, 04:25 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Webasto Air Top 2000 St STC 2015 2016 Model 12V Diesel Heater | eBay
This is all you need for the cabin, mount it under the second row seat. I had one in my last truck and I wore a T-shirt in the dead of winter
tom
Old July 25th, 2016, 05:05 PM
Roverlab
Trevor Griffiths
Ok, thanks for the replies!
Email is
Old July 25th, 2016, 05:38 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
George in Ridgewood NJ installed a cabin heater from an ambulance into his Series and Rohan's series. Two or three years ago Rohan showed up to Winter Romp in a tshirt cause it was so hot in his truck.
auxillary fuel tanks the rover shop For Sale - Parts 6 November 22nd, 2011 01:33 AM
Auxillary Fuel Tank Bajavet Defender Technical Discussions 2 February 6th, 2011 10:24 PM
D90 Auxillary Lights - Recommendations 1sttimer Defender Technical Discussions 5 March 2nd, 2010 06:32 AM
Auxillary Rear Light dalesmith71 Misc. Chit-Chat 20 October 3rd, 2006 04:17 PM
» Defender Registry
Mancar
emah
Defender
graham
Add your Defender
