Auxiliary Heat - Defender Source
Old May 20th, 2007, 06:41 PM
DAS-D90
Dylan Schlott
1994 Defender 90 ST
Auxiliary Heat
I have a 1994 defender 90 that i bought a few months ago. The previous owner had the auxiliary heat installed. Unfortunately it is always on! Does anyone know how to turn it off? is there a new switch somewhere i am missing?
Old May 20th, 2007, 08:06 PM
Take a picture of it and post it here, I am sure someone else has one or has had one.
Welcome to the board,
Old May 20th, 2007, 10:45 PM
bjenk
Brian Jenkinson
1994 D90
I would just take that OUT!!!! It will be a pain in you butt. Matter of fact I would just yank it out, box it up, and then ship it to me.
Old May 21st, 2007, 10:29 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
hahaha seriously
Old May 29th, 2007, 08:27 AM
andyrad
Andy Radlgruber
None.
Talking
The switch is on the left side of the dash next to the dimmer switch for your instrument cluster. At least that's where mine is.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old May 29th, 2007, 04:20 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
If its the one that uses the fluid from your heater hose there should be a shut off under the hood where they spliced off the heater hose to get the fluid. If there isnt one you can add one. try jc whitney for the shut off or even Home Depot. if you dont want the heater at all disconnect the 2 hoses that connect to the heater and get 2 new heater hoses.
then ship the heater to brian : )
even if u shut the electric switch off the hot fluid will still flow.
Old May 30th, 2007, 08:35 AM
andyrad
Andy Radlgruber
None.
Thats good to know because I am going to use the heater hoses for a heat exchanger and hot water shower, under the seat of the passenger. It would be nice to stop the coolant flow to that area so it does not get too hot.
Old May 31st, 2007, 02:36 PM
DAS-D90
Dylan Schlott
1994 Defender 90 ST
Thanks everyone, problem solved!
Old May 31st, 2007, 03:38 PM
How did you solve the problem? Find the switch, uninstall the heater or take the top off your truck?
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
Heat insulation blankets kellymoe For Sale - Parts 1 July 13th, 2005 04:54 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
