Aux Heater? - Defender Source
Old September 16th, 2004, 09:03 AM
NASD90
T B
None any more
Aux Heater?
Hello again;
I've heard stories of people adding a second heater to their D90s... has anyone here done it? I didn't see it in the FAQ or in the archives...
Yes, I know about new door seals and a drop curtain and all of that. But for hauling a full car of people long distances, this seems like a great option.
I'd like to look into seeing how other people did it before I get the tuffy center box in case I decide to mount it in there and cut holes in the back... Anyone have pics/model names?
Cheers;
Old September 16th, 2004, 09:21 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I have a Ebersbacher heater in my truck. It runs off the fuel tank and runs when the engine is off if you want to warm the cab. I live in California so hardley ever have need for it. But it is a nice option.
Old September 16th, 2004, 10:47 AM
NASD90
T B
None any more
Kevin,
I'm assuming you have something like the airtronic 2?
http://www.espar.com/htm/Specs/airtronic2.htm
Did you install it yourself or have someone do it? Electrics I have no problem with, but running a gas line...that I have not done. And where did you put it in your cab?
thanks,
Old September 16th, 2004, 11:19 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Chris,
It came with the truck when I bought it. It is mounted under the back seat and exhausts out the drivers side just behind the back door. Sorry I cant help with the install. I think I have the manual laying around somwhere. If I find it I can fax it to you if intereasted?
Old September 16th, 2004, 11:32 AM
NASD90
T B
None any more
No, but thank you very much... I have to figure out some minor points like "cost" and "how not to blow up my car messing with gas lines" first. Also how the hell I'd put this in a reasonably water resistent setup, as I'd still want to be able to take this thing in water.
Thanks again Kevin,
Old September 16th, 2004, 01:42 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Chris, my father's '95 came with a heater mounted behind the cubby box. He swears by it. When he traded for his '97 he had it switched over. I don't know much about it or the brand, but I might be in TN this weekend and check it out for you. I do know that it has it's own power switch, and is plumbed to the engine... It does the job very well!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old September 16th, 2004, 01:46 PM
excanuk's Avatar
excanuk
Nigel Rigby
94 D90
Chris,
I have an aux heater that is mounted in the box under the passanger seat. It blows heat into the rear just behind the passanger seat. It is controlled from a switch in the dash and runs just like the main heater with coolant lines. Somebody told me that it was from a 110 but I am not sure. It was installed when I bought the truck. If you want to see some pics let me know.
Nigel
Old September 16th, 2004, 02:36 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
From what I know, the Canadian 94s had an aux. heater standard. Coolant lines run to a small core and blower under the passenger seat with a small vent coming up through the back floor.
Tom
Old September 16th, 2004, 02:49 PM
dnewman9's Avatar
dnewman9
Dennis Newman
*SOLD*Conniston 97 NAS 90
I have seen this in the 4x mags, http://www.flex-a-lite.com/auto/html/mojave-heater.html
I bet this is relatively inexpensive. I know the Bronco guys also looked at a couple boat units that would melt wax in the interior of a Bronco.
Dennis
ps looks like summit has them for $149 http://store.summitracing.com/defaul...4923433+304506
Old September 16th, 2004, 03:19 PM
NASD90
T B
None any more
Canadian D90=warmer, makes sense.
I don't want to put anyone out...does anyone know of photos of this setup anywhere? I'd love to do a stock looking stall of this, if anyone has some info. Pictures would be slick, but as would be part numbers... anyone have ideas?
Thanks!
Old September 16th, 2004, 03:48 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
I'm in Houston for at least another week I think. If someone else doen't get you pics by the time I get home I'll get you a few.
Tom
Old September 16th, 2004, 04:25 PM
tim
Timothy Homewood
Defender 50th going topless
Hi Guys,
Not sure it helps, because we are deisel (not sure they do petrol)...In Europe (the coldest parts anyway) 'WEBASTO' is the heater of choice..and are supplied with a complete DIY fitting kit for Land Rovers. Checkout www.batmanuk.com/webasto.htm or you could probably just search out webasto.
tim
Old September 16th, 2004, 05:00 PM
Vadim
vadim
95 D90
Hi Chris.I found this link ,they sell heaters .May be it will help you. http://www.hilltoprv.net/index.asp?P...S&Category=227
Vadim
Old September 16th, 2004, 06:01 PM
NASD90
T B
None any more
The webasto definately looks like the pro way to go... although $800-900 is about 3 times what I wanted to spend on this one. The electrical unit that Vadim found for 40$ looks interesting, all I'd need is ONE person saying it's not crap and I'd get one to test it.
The mojave looks pretty boss though, but (PLEASE correct me if I'm wrong) doesn't the fact that it
"gets it heat from the hot water in your vehicle's cooling system (just like an O.E. unit), but has the advantage of fitting into a wide variety of confined spaces."
mean that it will succumb to the same problems as the stock heater? I'm under the impression here that an electrical unit will be ok, a gas unit will be fantastic, but what about this water unit?
I'd be interested in seeing what those boat heaters were that Dennis was talking about...
Am I the only one who has added one of these? I would have imagined everyone above the mason dixon would have put something in, or do you guys just put these away for the winter (or better yet, not ride with friends?)
Old September 16th, 2004, 09:07 PM
excanuk's Avatar
excanuk
Nigel Rigby
94 D90
Chris,
Here are a couple of pics of the aux heater in mine. I guess it was a Canadian option.....One bad thing with this setup is that the passanger seat tends to get hot even without the heater on as the coolant is still pasing through the heater core. I am considering putting a shut-off valve in for the summer. Hope this helps.
Nigel
ID:	1467   Click image for larger version
Old September 16th, 2004, 10:47 PM
dnewman9's Avatar
dnewman9
Dennis Newman
The main thing I see with a defender is the relative efficiency at which the aluminum body transfers heat. I would bet a good job of insulating the floor and ceiling with aluminum sided insulation pad would go a long way.
On the heater side, I bet the heater core size and amount of air flow through it also are not sized properly to heat the truck. I know in an early pop-up camper equiped Bronco the 8000 btu heater we had would make you sweat. I think if you could plumb the mojave heater to the right spot it would do the job given its 12k btu rating.
That being said the heaters the bronco guys put in are this one http://www.heatercraft.com You can also see it at http://www.completeoffroad.com which is a bronco specialty shop. Look under heaters. I have heard from several guys on the Bronco forums that this heater would seriously overheat the interior of an early bronco.
I only had my truck a half a winter and Colorado certianly is not that cold but i know after taking the vent cover off, under the dash, there was alot more hot air blowing into the cab. It may just be my imagination but it sure seemed warmer.
I had invisioned taking the heater, puting it under the passenger side storage compartment with the small circular vents pushing air out. I think its key to also have the proper amount of air inlets for supply.
Dennis
Old September 17th, 2004, 03:29 AM
Vadim
vadim
95 D90
http://www.sportsimportsltd.com/12vo300wahef.html This one goes up to 300 watt,and only $84.95 Check it.Or you can use power inventer from 12 V to 120 V ,and install some small size "wall" mount fans ,then it will be toasted worm It still be cheaper than $700 or $800. Good luck.
Vadim
Old September 17th, 2004, 12:31 PM
NASD90
T B
None any more
Thanks to everyone for all their help... I'll be buying up parts in the next week or so and I'll be sure to take pics for anyone who wants. I didn't even think that I'd have to run heat tubing to vents, we'll see how this goes...
Thanks again for all your help!
Old September 21st, 2004, 06:35 AM
nickt's Avatar
nickt
Nick Taylor
1998 Ex-Camel Trophy 110
I've an Eber Hydronic 4 in both the diesels and can't recommend it highly enough.
http://www.espar.com/htm/Specs/water/D4Wspec.htm
Have to agree that a bit of insulation helps in the ally Defenders though.
Cheers,
Nick.
Old September 21st, 2004, 08:25 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Not your imagination. I did that last winter and it made a big difference.
Chance
heater
FS Defender aux heater ECR For Sale - Parts 9 March 31st, 2009 10:24 AM
aux heater in defender 110 d90boy Misc. Chit-Chat 3 October 10th, 2007 09:24 AM
Removing aux heater core cpk Defender Technical Discussions 9 March 18th, 2007 07:34 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
