AutoZone tool hire ia awesome! - Defender Source
Old May 19th, 2012, 11:35 PM
Had a mysterious loss of coolant which has been getting worse over last couple of days ... Suspected the worst ... Head gasket ...
Went to autozone to rent a head gasket leak test kit and whilst there also got a pressure tester
Pressure tester found problem straight away ... Pumped cooling system up to pressure And hose leak immediately made itself known. The b'stard hose behind the water pump of course! Few hours with a spot light and some modified hoses from autozones selection and all fixed.
Tomorrow will test for head gasket leak but hopefully that's not a problem.
Cost for rental?
Zero dollars.
Having the right tools for the job is priceless and zero price is even better.
If you have overheating problems ... Rent a pressure tester and check the integrity of your cooling lines.
Old May 20th, 2012, 08:34 AM
They have helped me before with their free tool rental... Great store
Old May 20th, 2012, 08:59 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Make sure you join the rewards program. After 5 purchases of 20 dollars plus gets you a decent reward (I think 20 bucks).
Also the one by me gives me 10 percent off for being a Veteran.
Tool boxes - Troy Smith jabber Misc. Chit-Chat 2 March 8th, 2005 09:55 PM
Perfect Rover tailgating tool Burke Misc. Chit-Chat 9 July 21st, 2004 04:32 PM
What's In Your Tool Kit? javelinadave Misc. Chit-Chat 18 May 6th, 2004 08:26 PM
Defender 110 and 90 tool kit mpodgorski For Sale - Parts 5 May 4th, 2004 09:17 PM
Fiberglass hardtop tool PT94D90 Defender Technical Discussions 3 March 29th, 2004 08:44 PM
