Automatic Transmission flush or drain? - Defender Source
Old May 31st, 2014, 06:45 PM
Anschluss
T B
white 1997 Defender 90 NAS
Hey people; I have a 1997 D90 automatic with 82000 km. Low, I know, but I'd like to change over to Amsoil synthetic. Should I flush or drain? I realize a lot of oil stays put from a draining but aside that...is there any concerns about flushing these auto transmissions? Of course I have a new filter/screen ready to go. Thanks for any input!
Old May 31st, 2014, 07:55 PM
The way to do it is to just drain and refill with non-synthetic ATF. Do the filter if you must. Be aware that even at those miles there is a small chance the thing dies from the change. Doing the drain and refill minimizes that risk. I would not flush.
Old May 31st, 2014, 07:59 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
AFAIK, ZF does not recommend synthetic fluid for these transmissions. In my experience, synthetic fluid may damage the governor seals. Just change the oil at the specified intervals with the specified fluid.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 1st, 2014, 07:52 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
X3. I would not flush. I have the same truck and have taken this advice from these guys here years ago and all has worked out very well. Mine is my daily driver for almost 10 years and she's up to 135k with no issues. She been the most reliable vehicle I've ever own. Staying up on fluids and filter changes is sort key to these tractors. If your fluid is clean that's a great sign and that should give you comfort all is well. Simple drain and replace without over/under filling should be fine.
Good luck
Clay
drain, transmission
Sutars Recessed Flush Mount 12v sockets Uncle Douglas The Flea Market 14 August 23rd, 2012 09:25 PM
transmission drain and fill rover4x4 Defender Technical Discussions 24 November 16th, 2011 02:31 PM
Need to change front timing cover seals, auto trans flush... NY/NJ/MA/VT/CT area? KKilo23 Defender Technical Discussions 4 September 21st, 2009 03:35 PM
Flush mounted rotating Pintle Hitch dmarchand Wanted 12 May 9th, 2008 12:51 PM
How do you flush a diesel tank EdHsu Defender Technical Discussions 8 November 19th, 2004 05:48 PM
» Defender Registry
Pumkin
natas
D90
bneri
Add your Defender
