Automatic Shift Box Assembly (Diagram Needed) - Defender Source
View Poll Results: What's your thoughts on the Rover NAS import stop.
Not economically viable? 0 0%
Domestic competitors said "#!@$% - No!" We have nothing to offer as it has and continues to be. 0 0%
It's complex. 0 0%
All of the above. 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old August 6th, 2015, 04:06 PM
justme
Justme
1997 D90 NAS CA Soft Top
Exclamation Automatic Shift Box Assembly (Diagram Needed)
G'Day All,
3 Days in the wake-up (...only if time grew on trees)
I'm overhauling my auto shift box assembly on the rough, e.g., no diagram, DIY, cleaning, inspecting, etc.
1. Micro-contact proximity switches are erratic verified by continuity tests and park-lock solenoid not constantly releasing.
2. Unknow reassembly for bottom-end finger-shift-lock tension spring and associated spring wire-stop.
3. Hand shift lever shaft wont clear micro-switch mount after removal of e-clip and sliding shaft toward passenger sided for anticipated removal. (This is where the upper passenger side micro switch mount obstruction comes into play (casted, e.g., not removable).
Respectfully,
D90 NAS CA '97 (Soft-Top of Course -- Wagons Don't do Rain
(I still digress with NA dealerships under factory warranty, e.g., pressure washed my factory cosmoline, RnR, everything possible w/o diagnostic of cause, etc.)
assembly
Automatic Gear Shift Questions Wildcat Defender Technical Discussions 8 March 25th, 2014 02:12 AM
Defender 90 97 NAS Automatic Shift Illumination Base Dogpilot For Sale - Parts 2 February 17th, 2014 12:40 AM
T-shift Handle 97 Defender Automatic Khmorrow Wanted 2 January 5th, 2013 09:58 AM
standard shift vs. automatic cobb Misc. Chit-Chat 15 May 10th, 2005 04:08 PM
I'm trying to get the automatic gear shift handle off and I need some help KeithElisa Defender Technical Discussions 4 November 30th, 2004 12:01 PM
