Automatic Gear Shift Questions - Defender Source
Old October 17th, 2013, 08:52 PM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
Apologies in advance for the stupid question, I've only had my D90 a week...and it's been a dozen years since I owned my last one.
I noticed the lights around my gear shift wouldn't illuminate with the headlights. I was in the shop today for a 90k mile service and they replaced the gear shift illumination bulb.
Now the shifter is illuminated at all times, regardless of whether the headlights are on. Is this normal for a 97 NAS D90 or should they only illuminate when the headlights are on?
In addition, the gear shift surround (with the actual letters/numbers on it) is VERY hot to the touch when the vehicle is on. I haven't taken the infrared thermometer to it yet, but I would guess it's getting above 120 degrees when the lights on. When the bulb was burnt out, I didn't feel any excess heat from this area. Can all that heat be from the bulbs that illuminate the gear shift? If so, have people been replacing these with LEDs?
Thanks for your input!
Old October 18th, 2013, 04:44 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Nick, I'm not sure about the illumination on the shifter on the NAS but I linked mine to the lights as I thought it was sensible when I built the truck.
I've replaced the bulbs on mine with LED's as I also noticed the surround was hot despite me changing the rating of the bulbs.
regards
Gren
Old October 18th, 2013, 04:50 PM
regards
Gren
try LED replacements they run cooler
Old October 18th, 2013, 05:53 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Light is on all the time - try a smaller bulb, if you ever pull the console. Mine is hot, too.
-Ren Ching
Old October 18th, 2013, 06:26 PM
Oannes's Avatar
Oannes
Aaron
1997 NAS D90 (Original Dream Car)
After it went out the 2nd time I put LED replacement in mine ran cool always and never went out again.
Aaron
We make a living by what we get, we make a life by what we give. Sir Winston Churchill
1984 Defender 130 (In the middle of build)
1988 Defender 110 CSW (Original)
1964 Series IIa 109 5 door (South Africa in a thousand pieces)
1973 Series II 109 5 door (Australia)
1997 NAS Defender 90 (Already sold so)
2013 Chevrolet 2500HD (work horse)
Old October 19th, 2013, 01:42 AM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
Thanks for the replies. I will move forward with the LEDs. Do you know what size/style LED I need to order to replace those bulbs?
Can I easily replace them myself or should I leave it to my mechanic? I haven't tried to pull that area apart before, so I'm not sure where to start.
Old October 27th, 2013, 04:06 PM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
I'm going to order LEDs soon to replace my interior lights. Does anyone know what type of bulb is needed for the automatic gear shift illumination?
Old March 24th, 2014, 02:14 PM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
I still haven't ordered my LEDs to take care of this project. Does anyone who has done it before want to chime in on the correct type of LED bulb I need to purchase for this?
Old March 25th, 2014, 02:12 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Ian Gregory published a list here of LED replacement bulbs for the '97's.
You may also want to look up the thread here about how to service the shifter film issue about how to prevent them from prematurely failing & a less expensive replacement unit.
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
standard shift vs. automatic cobb Misc. Chit-Chat 15 May 10th, 2005 04:08 PM
I'm trying to get the automatic gear shift handle off and I need some help KeithElisa Defender Technical Discussions 4 November 30th, 2004 12:01 PM
difficult to shift my 94... JRowe Defender Technical Discussions 8 January 26th, 2004 01:21 PM
