Automatic Conversion Wiring for Reverse - Defender Source
Old December 27th, 2012, 11:35 AM
CDeWan
Clay DeWan
5.3L beastie
95 wiring harness in D-90. Using RRC Automatic. Need a pic of the wiring to get reverse to work. Does anyone have a pic of what you did? Thank you!
Old December 27th, 2012, 01:52 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Do you mean to get the reverse light working ? If so, it's on the multi-connector on the side of the trans. Have a schematic somewhere but you should be able to buzz it out. the other pins are for the neutral switch, for the engine ECU.
Old December 27th, 2012, 10:23 PM
CDeWan
Clay DeWan
5.3L beastie
swith
yep just for the reverse light so I should just see which ones complete the circuit using an omh meter then when the tranny is in reverse, correct?
Old December 27th, 2012, 10:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Yup... sorry, can't find the RRC wiring diagram I had.... prob got lost when we emigrated. Am sure it's online or someone will have a copy around.
conversion, wiring
ZF Auto / Automatic Conversion - Let's see pics rijosho Defender Technical Discussions 122 October 4th, 2017 10:05 PM
automatic shifter for your conversion draaronr For Sale - Parts 6 February 11th, 2009 07:31 PM
Manual to Automatic Transmission Conversion FlaD90 Defender Technical Discussions 0 November 25th, 2008 07:57 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
