Auto transsmision shifter lockout solenoid - Defender Source
Old August 17th, 2014, 02:29 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Had a situation on the trail that, due to the loss of power, my shifter was stuck in park... Is there an emergency by pass in a 97 d90 that will release the lock out solenoid?
Old August 17th, 2014, 03:28 PM
the rover shop
shayne young
Or you have to jump underneath the truck and release the cable on the side of the trans and manually put it in gear... Make sure you have someone start it before you do it... And pleeeease keep in mind that when you are under it and put it in gear, if someone isn't holding the brake on etc you could be runded over...
Old August 17th, 2014, 03:59 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
No power... Couldn't start it... Just wanted to get it into neutral for winching out to a place where we could work on it...
Old August 17th, 2014, 04:21 PM
the rover shop
shayne young
Then you just need to disconnect the cable from the left side of the trans and manually take it out of park...I think it's just held in by cotter pin..and a washer underneath it..don't lose it... Hope you're not in deep water...lol...
Old August 17th, 2014, 04:23 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Not water... Deep mud... Even better...
Old August 17th, 2014, 04:30 PM
the rover shop
shayne young
I assume you got it out already..
Old August 17th, 2014, 04:52 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Yah. Ended up dragging it up a slope out of the mud pit wit tires locked. I wanted to avoid that situation next time.
Old August 17th, 2014, 05:38 PM
Transfer box in neutral should do the trick.
Old August 17th, 2014, 05:42 PM
Not quite sure how BDR did it but I don't need to step on the brake of my build to move it out of park. Curiously it will even start in gear...
Old August 17th, 2014, 06:23 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
That was my first thought but I couldn't get the transfer box out of gear either...
------ Follow up post added August 17th, 2014 03:23 PM ------
They probably removed the lockout solenoid.
Old August 17th, 2014, 06:36 PM
the rover shop
shayne young
Nope...if it will start in gear they have bridged or eliminated the neutral safety switch.. Check to make sure you have reverse lights..
------ Follow up post added August 17th, 2014 06:39 PM ------
If it was that easy to take it out of gear it would make it that much easier to steal it on a tow truck.. I think you will find the 97s have a lockout solenoid which prevents moving high to low unless the ignition is on..easy enough to bypass/remove but as mentioned..let's someone put it in neutral without the key on..
Old August 17th, 2014, 06:39 PM
I guess on a '97 you must have the transmission in neutral to switch to low range. I can switch mine with the truck off, and I thought you could do that with Disco's too, but I'm probably wrong.
Old August 17th, 2014, 06:57 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Disco's have both the shiftlock solenoid and the Transfercase solenoid. The shiftlock solenoid can be removed. I removed my Transfercase solenoid and then the truck wouldn't start. Apparently the alarm ECU gets a ground from the solenoid. I had to run a new ground to one of the wires on the Alarm ECU and then it would crank and fire.
Radio lockout apierce Defender Technical Discussions 3 July 18th, 2013 02:14 PM
auto console and shifter MRROVER Wanted 2 March 23rd, 2010 11:29 PM
Hi-Lo-CDL shifter, Auto vs Manual? PCRover Defender Technical Discussions 2 March 17th, 2008 12:42 AM
Need 97 auto trans shifter light unit thingy wicks Wanted 2 December 22nd, 2004 12:59 PM
Transsmision fliud ??? Vadim Defender Technical Discussions 8 September 27th, 2004 10:10 PM
