auto transmission get stuck in gear - Defender Source
Old April 12th, 2012, 12:57 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
So every now and then my gear shifter mechanism gets stuck in either P, R or D. I found out that there is a small clip underneath the cover on top of the shifter nob that falls off. Was just wondering if I should just replace this clip with a new one or if some oil on the mechanism would fix the issue? Has anyone else had this issue? Thanks.
Old April 12th, 2012, 11:28 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Yep, had this a lot, got a replacement clip.. problem solved. Rovers North has them for $15 or something.
-Ren Ching
transmission
'94 Disco auto transmission problem cgalpin Defender Technical Discussions 19 July 27th, 2006 10:20 AM
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
Auto transmission gonewheeln Wanted 4 August 14th, 2005 02:23 PM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
