Auto transfer case - Defender Source
Old September 16th, 2012, 11:23 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Auto transfer case
Just wondering if the automatic d90s use the same transfer case as the r380?
Old September 16th, 2012, 11:40 AM
yes indeed
Old September 16th, 2012, 11:41 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Great thanks!
Old September 16th, 2012, 05:28 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
1.4 vs 1.2 ratio
Old September 16th, 2012, 05:46 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Autos have higher gears?
Old September 16th, 2012, 05:50 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
No, NAS Autos are 1.2 same as stick. 94/95 (Stick) and 97 (Auto) NAS V8 trucks all run 1.2 cases. ROW Diesels and/or the smaller gas engine trucks run different ratio cases.
Old September 16th, 2012, 07:35 PM
ron's Avatar
ron
Ron
i believe stick is 1.4 and auto is a 1.2
Old September 16th, 2012, 08:58 PM
Originally Posted by ron View Post
1.4 vs 1.2 ratio
Never seen a v8 90 with a 1.4. To my knowledge only 110's had 1.4 tcases. tdi 90's had 1.4's
------ Follow up post added September 16th, 2012 09:00 PM ------
Old September 16th, 2012, 10:16 PM
what he said
I've heard that some early NAS D90's had them.
Old September 16th, 2012, 10:33 PM
my 94 had a 1.2. Working in a dealership have you ever seen one ?
Old September 16th, 2012, 10:58 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
My 97 came with a 1:4 As far a I know everyone I have talked with that has a 97 says there's are 1:4 also. from what i have been told all the auto 90's were 1:4 to make up the difference of the 265 tire compared to the disc 1:2 with smaller tires.
Old September 16th, 2012, 11:06 PM
carlosz's Avatar
carlosz
Carlos
i believe my 87 rangie nas 3.5 v8 has a 1.4:1 t case ratio even thou it runs a 4.6 now a days
Old September 17th, 2012, 12:01 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Here you go. Per the Parts list:
NAS 90 (Stick) = LT230T - 32D - 1.214:1
NAS 90 (Auto) = LT230Q - 40D - 1.211:1
The 0.003 difference in the 90 box ratios is because of the change from the T to the Q versions of the box not because of the change from Stick to Auto.
My 97 D90 (Auto) is a 1.2. My 94 D90 (Stick) is a 1.2 (but it may not be the original unit). My 96 D1 (Stick) is a 1.2. My 98 D1 (Auto) is a 1.2.
HTH
Ian
Old September 17th, 2012, 12:54 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
HTH
Ian
Now I know why I'm having trouble finding a defender... You are hogging them all!
Old September 17th, 2012, 06:25 AM
If the OP looking to swap Gearboxes isn't there a short adapter drive needed when using the auto box?
Old September 17th, 2012, 09:38 AM
Drew is the one who told me, so I imagine he has.
Old September 17th, 2012, 11:50 AM
I have a tcase out of a 97 D90 in my 130 (purchased in desperation when I grenaded the original 1.4 on Mass Pike in order to get home). It is a 1.2. The other NAS d90's I have worked on all have had 1.2 stickers on the tcase.
Hoping to get the 1.4 tcase I have for the 130 in this week for conclave but that may be a bit optomistic. Had hoped to get that installed and run up on 35's on steelies.
Old September 17th, 2012, 12:22 PM
97s had the Q as mentioned and also have the solinoid on top to prevent you from shifting when you should not.
All NAS D90s had a 1.2 box when they left the factory. All NAS 110s had the 1.4 box when they left the factory.
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
