auto box swap - Defender Source
Old November 21st, 2011, 01:29 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
auto box swap
Has anyone done a write up on swapping the LT77 or R380 with an auto box ? Toying with the idea of dropping in a Disco auto box in a 110, still not sure if I would have it powered by a 4.6 V8 or a 300tdi . Is a computer needed for proper shift points in the Auto box , or can it stand independently like the GM TH350 or TH400 transmissions ?
Chris "V"
Old November 21st, 2011, 02:22 PM
The Dro
Dro
1988 Ninety
Chris,
One of the things I was told about having the 4.6L on my DI, is that the ZF 4HP22 will not handle the torque. I never had an issue. But I know first hand of guys that had issues with the 4HP22 and their 4.6L.
One option for the 4.6L is to get the Ashcroft ZF 4HP22 with the ZF 4HP24 guts. (see the stage 1 and stage 2 options)
http://www.ashcroft-transmissions.co...d&productId=51
The Disco I does not have a tranny ECU... The DII with 4.0 have the electronic version ZF 4HP22 EH
I have no knowledge on 300tdi.
Old November 21st, 2011, 11:58 PM
CDeWan
Clay DeWan
5.3L beastie
I am currently building a 90 project and have gone with a 4.6L mated to a RRC 4.2 classic tranny. There is a guy here locally - Nick Markiw who made my shifting set up from a kit off of summit (I can't remember the shifter) but the set up turned out nice if you need the shifter, I can get you his info.
Old November 22nd, 2011, 10:53 AM
Chris Velardi
Chris Velardi
1975 101FC
Clay are you going EFI or Carburetor ? , wondering if getting a classic 4.6 rangie and using the entire engine , and trans might be the easiest way
Chris "V"
Old November 22nd, 2011, 01:13 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
They did make a few automatics with the 300 Tdi. In order to overcome the power loss they made it drive by wire and played with the adjustment on the pump. From what I have heard it still was not as peppy as the R380.
Land Rover 110
Old November 22nd, 2011, 02:07 PM
No classics came with the 4.6 as it was introduced in 1996 in the 4.6 HSE and that transmission will not work.
The transmission you want is the ZF HP22HD out of a 93-95 LWB. Keep in mind that you need everything on the back of the engine from the same truck (ie a GEMS or 14CUX) if you are swapping in an auto.
What drivetrain was in the 110 originally?
Old November 22nd, 2011, 02:21 PM
I'm bulding a 110 now with 4.2 and auto box. Using a D1 shifter and an Ascroft defender auto console.
Old November 22nd, 2011, 02:50 PM
Chris Velardi
Chris Velardi
1975 101FC
Not sure what came stock on this 110 from the factory , but right now it has an LT77 and the V8 with blocked off injection ports running edelbrock intake and carb
Chris "V"
Old November 22nd, 2011, 03:20 PM
Fly by wire was only on the 97's and 98's to my knowledge. It was an attempt to compensate for the power loss from the egr and catalytic converter that came with those model years. Tdi auto's started in with the 200 tdi disco's up to the 97 year with no fly by wire. I have a tdi auto trans and am considering doing a 300 tdi 110 auto. If I do it I'll use a 1.4 tcase not the disco 1.2.
Old November 22nd, 2011, 04:25 PM
draaronr's Avatar
draaronr
Here
LR3
transfer case depends on what tires you have, with 285s 1.4
Old November 22nd, 2011, 04:45 PM
Chris Velardi
Chris Velardi
1975 101FC
So best options so far look to be
1) 300tdi, ZF HP22HD mated to the stock 110 1.4 transfer case
2) 3.9-4.2 disco motor, autobox, stock 110 1.4 transfer case
3) 300tdi ; 595 Ashcroft adapter , and V8 auto box again with 1.4 transfer box
4) ?
Chris "V"
Old November 22nd, 2011, 07:54 PM
All 110's have come with 1.4's or 1.6's up to the td5. 1.2 is too tall for a 110 auto imo
Old November 22nd, 2011, 08:01 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have one of each, both in Range Rovers and the auto (fly by cable) is no slower than the 5 spd (seat of pants). The motor for the auto is actually rated as slightly more powerfull than the Defender version by a couple of horseys.
If you use the V8 auto trans with the diesel you'll need to do some additional work to the torque converter and change the governor housing or it will have some ugly shift issues. The standard diesel version HP22 is fine unless you are planning on some significant power upgrade to the motor.
Matt Browne
Old November 22nd, 2011, 09:55 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Prior to Matt sorting this out, I have pretty good experience with the V8 hp22 behind a diesel. You can get away with it for about 1-2 years. You will experience no 1st gear and very little 2nd gear if you don't address the valve body and torque converter. The auto will eventually eat the 2nd gear clutch pack and contaminate your fluid and valve body. You'll experience no shifting out of 1st once this happens. The symptom of the clutch pack contamination is no shifting out of 1st or reverse until the trans fluid warms up.
Old November 22nd, 2011, 10:33 PM
draaronr's Avatar
draaronr
Here
LR3
i would go with 1.2 with 4.10 lockers personally with a set of 265s. I've had that and loved it, great on the highway, a little underpowered offroad unless the tcase was in low, but daily driving around without big hills in my town it was great.
Old November 23rd, 2011, 06:30 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
That's a great set up and I use it frequently.
Matt Browne
Seat Box / Auto Trans Selector Removal 97-D90-736 Defender Technical Discussions 3 September 2nd, 2010 09:28 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
ZF Auto box, works $150.00 RedRhinoProducts For Sale - Parts 1 October 17th, 2004 10:44 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
