autmatic transmission life expectancy? - Defender Source
Old March 21st, 2012, 11:06 PM
KYRover
Colby
2012 LR4
Pardon my spelling. *automatic*
How far do the auto's in the NAS D-90's usually go before needing a rebuild? I did a search and didn't find many answers.
Old March 21st, 2012, 11:37 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
They usually last about 30 seconds shorter than when you say "oh fuck".
Kidding aside I don't think you will get a straight answer on this but good luck.
Old March 21st, 2012, 11:48 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Seems like discos get 150k out of them pretty easy. I bet it would be prett close to that. New rebuilt Ashcroft units from lucky8 are like 1300 I think. I'm not too worried about mine. Kind of excited to get an Ashcroft when the day comes.
Old March 22nd, 2012, 08:59 AM
KYRover
Colby
2012 LR4
So it doesn't sound like the automatic transmission is a common source of problems in Defenders?
Old March 22nd, 2012, 09:01 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No more than the manual.
Old March 22nd, 2012, 09:08 AM
KYRover
Colby
2012 LR4
Thanks for the replies.
That pretty much answers my question.
Old March 22nd, 2012, 09:22 AM
Your only real problem will be when you can't get it out of park because your brake switch has gone - no brake lights means not getting it out of park.
Old March 22nd, 2012, 09:45 AM
200k easily
Old March 22nd, 2012, 10:52 AM
If you change the fluid every 30k and drive the truck fairly regularly they will last forever.
Old March 22nd, 2012, 11:11 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I have an '85 BMW with 225,000+ on a Zf 4hp22, change ATF every 60K still runs like day 1. The Zf has exactly the same gear ratios as the units in the Rovers.
Old March 25th, 2012, 02:18 AM
Broncoduecer
peter
D90
But you don't need to hook that up if you convert your manual to an auto. So you do get rid of that pesky issue if you preform a swap. All I have is the neutral safety switch to the starter solenoid relay.
Old March 25th, 2012, 09:32 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
That ZF Box is probably the most reliable thing on a Defender. Bullet proof if you change the fluid occasionally.
transmission
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Inspirational Speech... norros Misc. Chit-Chat 4 June 16th, 2005 12:51 PM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
D90 Life Span asalnick Defender Technical Discussions 4 November 11th, 2003 12:24 PM
